Colchester chipmaster dual dials
Adam24/06/2018 21:26:39
70 forum posts
81 photos
Hi everyone. I have a Colchester chipmaster I recently acquired and I measured the distant on the slide with respect of the dual metric imperial dial. It says one revolution is 400 thou but it's actually half that.
Is this normal?
Bill Davies 224/06/2018 21:44:35
357 forum posts
13 photos
Hi, Adam.
Assuming the cross slide, the dial movement indicates the amount removed on the diameter. Half off radius (actual slide movement) equals amount off diameter.
Bill
Muzzer24/06/2018 21:45:06
2904 forum posts
448 photos
Yes - it takes 400 thou off the diameter, which is often what you want on a lathe.
Murray
PS - I've never checked on my Bantam but I assume the compound / top slide is different ie direct reading, as it could move at any angle to the axis.
Edited By Muzzer on 24/06/2018 21:55:40
John MC25/06/2018 07:50:54
464 forum posts
72 photos
My Chipmaster has dual dials, takes 400 thou off diameter. While the imperial dial is accurate the metric is not. If I zero the dial in "thous" then the cross slide will consistently return to the zero position, checked with a DTI, zero on the metric scale is inconsistent. Anyone else noticed that? I tend to use the DRO so not a problem, would be nice if it was accurate on both scales.
My Triumph has dual dials fitted, absolutely consistent in both ranges.
Adam25/06/2018 10:15:48
70 forum posts
81 photos
Of course!! It's diameter!! This is my first real lathe so I'm still learning. I guess we all start from somewhere. Thanks for the responses. No doubt I'll ask more easy questions later.
SillyOldDuffer25/06/2018 10:55:17
10668 forum posts
2415 photos
Posted by Adam on 25/06/2018 10:15:48:
Of course!! It's diameter!! ...
No 'of course' about it. Traditionally British lathes measure depth of cut. Measuring diameter (which I find more natural except when cutting threads) is a beastly American innovation circa 1890.
My Chinese mini-lathe dial measured depth, it's big brother measures diameter. Not much consistency in the world of lathes.
Always worth double-checking before using an unfamiliar machine.
Ian S C25/06/2018 12:57:13
7468 forum posts
230 photos
My Taiwanese Lathe indicates diameter, and I got trapped when I did some work on a mates Myford 7 that indicated DOC. I'll have to check the Menzshed Boxford A, the dial is tiny, and not easy to read.
Ian S C
