Ron Laden | 24/06/2018 11:41:28 |
![]() 2320 forum posts 452 photos | Is it possible to purchase a stock/starter pack of round bar, ideally a mix of alu, steel and brass, short lengths say 6 or 12 inches. Just wondered if any supplier does this. Ron |
Paul Lousick | 24/06/2018 12:41:15 |
2276 forum posts 801 photos | Ron, I have not seen a "starter pack" of metal bars. When I first set up my home workshop, I bought a selection of different size steels and still have some of them. (Never had a use for some sizes after 5 years and a waste of money). It is better to buy the sections that you need for a project as you need them. But if I need some 25x5 flat bar x 200 long, (as an example). I will buy 1 or 2 meters and keep the remainder as stock, knowing that it is a size that I use. Metal supplers often have off-cuts which are sold at a reduced price. Also second hand steel merchants and ebay are a source of cheap materials. Paul. |
Jez | 24/06/2018 13:01:52 |
58 forum posts 1 photos | GLR Kennions sell packs - not mixes of metals though: https://www.glrkennions.co.uk/budget-packs.html I've bought them in the past and been satisfied...
Jez. |
JasonB | 24/06/2018 13:16:04 |
![]() 25215 forum posts 3105 photos 1 articles | Noggin End will also sell pack of various diameters of one particular metal, just click on each metal and the bundles will come up at the end of each type |
Frances IoM | 24/06/2018 13:36:44 |
1395 forum posts 30 photos | Is there not a nearby model engineering society you could join ? Other members may be able to supply you with small lengths while you get started and recommend sources of material - however you will soon need a small bandsaw (eg the cheapie sold by Chester tools (+ others) this will allow you to buy longer lengths of stock sizes eg 3m length of say 1", .75" and 0.5" round + square bar (free cutting EN1 at least at my small supplier seems more readily available in old imperial sizes) - if you buy eg ?100 worth of metal + collect yourself they will usually chop into 1.5m length easily carried in a car - work out what flat stock you want for a project and buy this at same time - buying very short lengths + the high postage cost is generally not a good idea unless you know exactly what you want it for - again locally steel is cheaper than ali but that may well be what the yard supplies most of - brass is even more expensive. Edited By Frances IoM on 24/06/2018 13:37:22 Edited By Frances IoM on 24/06/2018 13:37:44 |
David Standing 1 | 24/06/2018 13:39:52 |
1297 forum posts 50 photos | There are loads and loads of suppliers on eBay, such as this:
Phil Stevenson | 24/06/2018 13:43:38 |
90 forum posts 13 photos | Mallard Metal Packs http://www.mallardmetals.co.uk/ He sells single material packs - see his catalogue - but Rob (think that's his name) made me up a mixed bundle when I started. Different materials, profiles, etc. He was very helpful, plenty of advice. |
