Andrew Tinsley | 20/06/2018 18:13:52 |
1817 forum posts 2 photos | This must be a longshot, but! Amongst some gear cutters that I have acquired, there are some with no identification on them. Is it possible to work out what DP they are if I can get a good shadow graph magnification of the profile? They are definitely professionally made and have some coding on them, but nothing that remotely resembles a DP identification. Regards, Andrew |
Brian Wood | 20/06/2018 19:25:29 |
2742 forum posts 39 photos | Hello Andrew, I wonder if they have been slimmed down in width, taking off all the identification. As to reverse engineering what they were made for, maybe finding Unicorn hair might be an easier quest! What a pity Regards Brian |
Andrew Tinsley | 21/06/2018 08:01:42 |
1817 forum posts 2 photos | Thanks Brian, I thought that might be the case. It is a pity as they are pristine and very sharp! Now where did I see my last Unicorn! Thanks again Brian, Andrew. |
Hopper | 21/06/2018 08:07:20 |
![]() 7881 forum posts 397 photos | Well, if you measure the radius on the cutters with a radius gauge and measure the tip width, you might be able to extrapolate back from Ivan Law's charts on making cutters by the two button method and get a close idea of the DP. Then you would have to check the cutter against a gear of that spec to confirm. Could be tricky though. Ivan Law's book on Gearcutting would have details, but also quite a bit on the net about making gear cutters with the two button method. If you don't have a set of radius gauges, you might use a set of drill bits to meausure the curves on the cutters. Edited By Hopper on 21/06/2018 08:14:10 |
not done it yet | 21/06/2018 09:40:28 |
7517 forum posts 20 photos | Some extra clues, maybe? Any aquisition history? ‘Professionally made’ - do you mean a one-offs or manufactured on a series production scale? Are these a set (of eight?)? Use each one to cut a tooth form to full depth and compare the fit with known cutters in your possession? 14 1/2 or 20 degree pressure angle? Might be discernible. Arbor size? Keyway? More likely for someone to hazard a guess. Might even be metric for all we know! The others (less sharp ones) can, of course, be sharpened. |
JasonB | 21/06/2018 09:51:40 |
![]() 25215 forum posts 3105 photos 1 articles | Maybe a picture with the code that is on them would help others find that unicorn. Just because it does not resemble a DP identification the code could be for MOD or even bevel gears. |
Andrew Tinsley | 21/06/2018 17:38:30 |
1817 forum posts 2 photos | Hello All, Thanks for the help in the Unicorn hunt! I do have sets of radius gauges, so it is worth having a go as per Hopper (Thanks mate!). I will dig out the cutters and sort out the codes on the ones I have. They seem to have been engraved freehand, but the quality does indicate they have been professionally made. A visit to the workshop will follow shortly! Thanks everyone, Andrew. P.S. It just seems a pity to have what look like brand new cutters consigned to outer darkness..Even if they are no use to me. Someone else may be able to use them |
Andrew Tinsley | 21/06/2018 18:47:49 |
1817 forum posts 2 photos | Right, A little more information. One side has a K followed by a 4 figure number. The one I have picked up has K 3879 stamped on (or may be etched, difficult to tell). They all have K followed by the 4 figure number. This mark looks like a manufacturers mark. The other side of this cutter has V 11-35/1. They all have V followed by varying numbers, but with the same hyphens. This number has been done freehand with an engraving pen. I have 5 of the cutters , so maybe they are part of a series of 7 for simple gear cutting. Or perhaps this is a red herring! It looks as though the cutters have been cut down on the side with the freehand engraving. So it looks as though Brian is correct in his surmise. They look to be 3/4" bore. I don't know what a close, in size, metric cutter would be Any suggestions would be welcome. I have already given away those cutters that I am unlikely to need. If I can identify the cutter spec for these, I can probably gift them to a deserving cause. Thanks, Andrew. |
Neil Wyatt | 21/06/2018 21:04:59 |
![]() 19226 forum posts 749 photos 86 articles | Quite a challenge as to know the correct radius for a cutter you need pressure angle, dp and the number of the cutter. Knowing the radius you have to identify three different variables. My advice would be to offer them up to a few gears of about the right size and see if they 'fit'. Neil
Andrew Tinsley | 21/06/2018 22:08:25 |
1817 forum posts 2 photos | Hello Neil, I have tried the cutters in the gears that I have to hand, with no luck. I shall be asking around friends to see if they have a better selection of gears that I could try. Hello Hopper. I have tried using the radius gauges and find that it isn't too easy to select the correct radius. Need to go to Specsavers! I shall dig out the Shadowgraph and see if I can get a better idea of the radius. The cutters came from a gentleman who was a locksmith and clockmaker. There were also some cutters to produce ratchet teeth. Regards, Andrew. |
John Haine | 22/06/2018 07:11:50 |
5563 forum posts 322 photos | Posted by Andrew Tinsley on 21/06/2018 22:08:25:
..... The cutters came from a gentleman who was a locksmith and clockmaker. There were also some cutters to produce ratchet teeth. Regards, Andrew. So they may well be for clock gears, so DP & pressure angle won't be applicable. Maybe have a look at this? |
JasonB | 22/06/2018 07:16:23 |
![]() 25215 forum posts 3105 photos 1 articles | If he was a clock maker than they may not be involute form as that is not used on clocks, they have cycloidal form. |
