Adhesive to secure tap rose head in place
JimmieS04/04/2018 20:38:30
310 forum posts
The plastic 'rose head' disc on our kitchen mixer tap has come off. Any one suggest a suitable glue to reattach it?
Jim
Jeff Dayman04/04/2018 22:17:07
2356 forum posts
47 photos
Materials to be glued?
Photos of each part?
Can likely help but need more info.
John Rudd04/04/2018 22:32:49
1479 forum posts
Superglue/epoxy/contact adhesive/pva/spit....cheeky
Brian Sweeting05/04/2018 09:25:27
453 forum posts
Thought they were normally screwed on, check inside the spout.
JimmieS05/04/2018 22:15:25
310 forum posts
The tap spout end consists of the plastic rose with a smaller diameter flexible tube which is a posh fit into the rear of the rose.img_1425.jpg
Jeff Dayman12/04/2018 16:03:53
2356 forum posts
47 photos
Where's it broken? Can't see a break. Can we see the broken pieces apart (or the other part to be glued)?
Not enough info so far to be able to offer any suggestions. Don't know what you mean by a posh fit, and only guessing what you mean by a "rose", that is, maybe it's the bigger diameter end of the part with multiple passages as shown in your photo.
Maybe your terminology is 100% clear locally where you live, but it isn't clear to me. I've been designing valves and plumbing components at different times for several different fluid handling firms in North America for many years, so I can probably help, but need clear info to do so.
Edited By Jeff Dayman on 12/04/2018 16:08:05
Neil Wyatt12/04/2018 18:35:16
19226 forum posts
749 photos
86 articles
They are usually a push fit, but sometimes screw in. I have seen push in ones pop out before.
Do you know the manufacturer?
P.S. the part is a 'tap aerator'
www.tapsandsinksonline.co.uk/?s=aerator&post_type=product
Edited By Neil Wyatt on 12/04/2018 18:36:48
