Brian H | 08/03/2018 13:01:31 |
![]() 2312 forum posts 112 photos | I am interested in buying a set of keyway broaches size 1/16", 3/32" and 1/8". Can anyone suggest what type of press would be suitable? I have seen hydraulic workshop presses where the ram seems to be suspended on 2 springs and I'm assuming that there would be too much uncertainty using one of those but the are other types where the ram is bolted down. Any ideas what might be suitable and how the tools are held? Brian |
JasonB | 08/03/2018 13:13:27 |
![]() 25215 forum posts 3105 photos 1 articles | 1/16" and 3/32" can be done with a bench drill, that's how I do mine. larger than that puts a bit too much strain on the rack though I have got the 1/8" through by doing the smaller size first Now for 1/8" and above I borrow a friends hydraulic press which is this type |
Brian Wood | 08/03/2018 13:57:47 |
2742 forum posts 39 photos | BDH, The usual kind of mechanical broaching press [Marlco for example] has a geared head and a big capstan like operating boss to wind down a spindle with a toothed rack cut into it. They seem to command premium prices at machine auction sales and you will do well to secure one under £500 once all the VAT, buyers premium and VAT on that is included. Those additional costs to the hammer price account for about 38% of the sum Home and Workshop supplies have one on sale at £525 plus VAT plus delivery, this is a 2 speed version used more for pushing 3/8 inch broaches or larger. For the sizes you are taking about I would extend Jason's experience to include a broach of 1/8 inch, I have pushed those through steel gears for Myford wheels successfully. The job is eased if you have included a suitable size of pilot drill to hog out some of the material beforehand where you can I am planning to modify a damaged and therefore dirt cheap Chinese hydraulic crane to take me into the larger sizes Regards Brian |
FMES | 08/03/2018 14:04:20 |
608 forum posts 2 photos | Or one of these, throat size to suit your broaches **LINK** Regards Lofty |
Brian H | 08/03/2018 15:15:01 |
![]() 2312 forum posts 112 photos | Many thanks for the answers, does anyone have any idea how many tons would be required to a 1/8" keyway? I'm assuming less than 1 ton if the hand press can cope. Brian |
Roger B | 08/03/2018 15:22:25 |
![]() 244 forum posts 105 photos | I have information for a 3mm (almost 1/8" If you click on Percussive broaching tool for each size it gives the details. |
JasonB | 08/03/2018 15:41:06 |
![]() 25215 forum posts 3105 photos 1 articles | Force will also depend on what you are pushing the broach through. A relatively slim gear will only have 2 or 3 teeth cutting at any one time but if it is the hub of a reasonable size flywheel you may have 10 teeth engaged so 3-4 times the force needed. |
Jim Nic | 08/03/2018 16:38:53 |
![]() 406 forum posts 235 photos | The thickness of the component being broached will also have an influence on whether you can fit the whole shebang, component plus the broach sticking out the top, in to an arbour press. There is currently a 6 ton hydraulic press available from a seller on the Bay of EEs for £64.95 all in (Item 351730934471) if you have the funds, the workshop space and the ongoing need for such a tool. Jim |
Nick Hulme | 08/03/2018 17:25:18 |
750 forum posts 37 photos | Like Toggle Presses and Fly Presses, Arbour Presses are available in a wide range of sizes :D |
John Reese | 08/03/2018 19:22:47 |
![]() 1071 forum posts | Page 7 **LINK**
Brian H | 08/03/2018 20:22:35 |
![]() 2312 forum posts 112 photos | Many thanks for the link John, that is VERY useful. Brian |
