sean logie | 27/02/2018 10:34:08 |
![]() 608 forum posts 7 photos | Saved a quantity of 20mm galvanised steel bar from the skip at work ,it was off an old handrail so me being me took it home . Any ideas how the galvanizing will machine in the lathe. I know I should just go and try it but I'm bored at work today so I thought I'd ask 😉. Sean |
Hopper | 27/02/2018 10:44:24 |
![]() 7881 forum posts 397 photos | It's just zinc so machines right off without dramas. If you want to weld it, grind the zinc off first. The fumes are toxic when welding zinc plated stuff. |
sean logie | 27/02/2018 11:19:40 |
![]() 608 forum posts 7 photos | Yeh it's not nice to weld even after grinding . Sean |
larry Phelan | 27/02/2018 11:56:21 |
![]() 544 forum posts 17 photos | It machines alright,but is not always very round. As regards welding it, no it,s not nice ! |
Farmboy | 27/02/2018 12:19:11 |
171 forum posts 2 photos | You soon find out if you are welding galvanised steel as you can taste the zinc fumes. I was told to drink a glass of milk when that happened (only the one time), as the calcium helps counteract the zinc absorption. Preferably don't do it! Most of my welding was done outdoors so fumes would usually blow away. |
sean logie | 27/02/2018 12:22:04 |
![]() 608 forum posts 7 photos | I won't be using the material for welding projects ,it's just handy size to have. Sean Edited By sean logie on 27/02/2018 12:23:01 |
Farmboy | 27/02/2018 12:27:46 |
171 forum posts 2 photos | Sorry. Meant to add, I have turned galvanised with no problem, but the swarf can be a little dusty if it is old and weathered. |
Speedy Builder5 | 27/02/2018 13:29:16 |
2878 forum posts 248 photos | may be a poor quality steel as it didn't require much when in service as a handrail. You might find it hard to get a good surface finish. |
vintagengineer | 01/03/2018 10:00:26 |
![]() 469 forum posts 6 photos | To remove zinc, soak overnight in a saturated solution of malt vinegar and table salt. This will dissolve the zinc and works well on nuts and bolts!
Hopper | 01/03/2018 10:12:43 |
![]() 7881 forum posts 397 photos | Posted by vintagengineer on 01/03/2018 10:00:26:
Thanks for that tip. Could be handy for using hardware store bolts etc on old motorbikes without them standing out like dog's ears. |
Ian S C | 01/03/2018 11:08:36 |
![]() 7468 forum posts 230 photos | The galvanised nuts with the zinc removed will be a very sloppy fit on a standard bolt. Ian S C |
