3-Phase motor 4-pole or 2-pole?
John Hinkley10/02/2018 10:09:50
1545 forum posts
484 photos
I'm thinking ahead, here, a bit. When we move house next month, I intend to convert my Warco VMC mill with a 3-phase motor, VFD and pendant remote, while everything is accessible and before it's positioned in its final resting place. My query ( as a fully qualified numpty where electricity is concerned ), is do I go for a 2-pole or 4-pole motor. What are the pros and cons of each? As far as I can ascertain, the 4-pole will produce a smoother power/torque drive. Is this correct?
I will be sourcing the parts separately ( 'cos I'm a cheapskate! ) and have already selected a Huang Yang VFD as my preferred unit.
Thanks in advance,
Edited By John Hinkley on 10/02/2018 10:10:39
Oldiron10/02/2018 11:08:12
1193 forum posts
59 photos
I also have the HY VFD's and find them an excellent unit. I went for a 2 pole motor for my Boxford lathe & Mill. I picked my motors from tecmotorsdirect.com They work together really well and have had no problems at all.
Have a look here for differences in 2 & 4 pole. **LINK**
Hope this helps regards
Edited By Oldiron on 10/02/2018 11:10:08
John Rudd10/02/2018 11:20:36
1479 forum posts
I went with a 4 pole 1400 rpm motor when I went the vfd route on my 626 mill, purely to retain the original speeds.....
A 2 pole unit will give you twice the rpm top end if you ever needed it....but of course you can slow the motor down with the speed pot.....the other thing is, with the 2 pole motor, cooling is less of a problem at lower speeds because the motor is doing twice the rpm for the same spindle speed if thats any issue.....
Pay your money and make your choice as they say.....
norm norton10/02/2018 11:21:19
202 forum posts
10 photos
Three phase 2 pole motors will run at twice the speed of a 4 pole, when fed at the same frequency. From memory, typical 4 pole motors are running at about 1400 RPM whereas the 2 pole version will be around 2800 RPM.
It is a nice way of increasing the top speed of a mill or lathe providing the spindle can cope. Then you can use the VFD to drop the speed right down. People will say that you should not run a motor at half speed and full load, but if the motor is well sized and the work typically light it gives you a big speed range.
Norm
Sorry John 1, John 2 and I posted the same time and repeated the same story! at least we agree!
Edited By norm norton on 10/02/2018 11:22:46
Clive Brown 110/02/2018 11:23:08
1050 forum posts
56 photos
Hope I'm not stating the too obvious, but a 2 pole motor runs twice as fast as a 4 pole motor for a given supply frequency. Approx. 1400 v. 2800 rpm for a 50Hz. supply.
Edit. Beaten to it!
Edited By Clive Brown 1 on 10/02/2018 11:24:22
John Hinkley10/02/2018 11:47:26
1545 forum posts
484 photos
Thanks, all, for your collective input. It looks like I'll go for a 4-pole, then. I don't think I'll need the higher speeds a 2-pole will give. Just have to sqirrel away some funds from the kitchen refurb kitty!
John H.
John Rudd10/02/2018 11:54:18
1479 forum posts
JohnH,
Going for a 4 pole motor doesnt mean you cant increase its speed....thats what the vfd will do for you....
As an example, my 12 x 27 lathe was fitted with a dc motor giving a top speed of around 2000rpm at the spindle.
I swapped it for a 3 ph motor, 2 pole to get near, but not near enough, so I wound the frequency up on the inverter.....ergo, if you wanted a bit more speed from your 4 pole, you could wind up the Hz on the inverter to give a bit more...( I took mine up from 50Hz - 2800rpm to 70 Hz, giving me a motor speed errr....well a bit more...you do the maths...laugh ......)
Best of luck with the conversion.
Edited By John Rudd on 10/02/2018 11:54:43
Mike Poole10/02/2018 12:43:57
3676 forum posts
82 photos
As usual in life there is always a trade off. Had you gone for the 2 pole motor and had to slow it down with the inverter, then if you run at 50% speed you will have about 50% power available. I think that good torque at low speed is desirable if you want to run a large facemill. I have a VMC and will do the conversion one day and I will go for the 4 pole motor.
AJW10/02/2018 14:22:31
388 forum posts
137 photos
Just bought a Brooks Crompton 3 phase motor which is VFD friendly and specified as being quite happy at more than twice it's rated 1330 rpm.
Alan
