Clarke metal worker lathe toolpost stud size
Matt Martin02/02/2018 18:55:33
3 forum posts
Hi brand new here. I have the above lathe and have just inboxed a quick change toolpost. Thankfully the issue of tools never sitting quite centre will now be sorted but as the toolpost is taller than the original one the stud to tighten it down is now too short. I shall make a new handle that will sit further in the toolpost with a shoulder on it but I have no idea what size the thread is. It looked to me to be around 10mm but I have tried an m10x1.5 and m10x1.25 and whilst these seem about the right size they do not turn any further than a couple of mm. So I believe it to be an imperial size. Have you any suggestions on what sizes this could be?
Many thanks.
Martin Shaw 102/02/2018 21:44:01
185 forum posts
59 photos
Matt
This is a Sieg lathe made in China, the tool post stud is definitely not imperial. I have a similar machine and when I put a QCTP on mine it came with a suitable sized stud to replace the original, and works fine. I would check the thread in the topslide for damage and if necessary run a tap through. Of course if you bought the lathe secondhand a previous owner might have done something weird.
Martin
Edited By Martin Shaw 1 on 02/02/2018 21:44:22
Wout Moerman02/02/2018 22:20:53
57 forum posts
My SIEG C2 has a standard M10 thread. So that's 1.5 mm pitch.
David George 102/02/2018 22:46:48
2110 forum posts
565 photos
Hi Matt it is possible the stud has stretched giving you a false pitch check the hole with a known thread.
David
Matt Martin02/02/2018 23:49:18
3 forum posts
Thanks for the replies here, I’ve just seen them. I ran a number of taps and dies in both threads, and although needing a clean up they appear to be an m10x1.5. Not the best condition it would seem. Thanks for the assistance I didn’t want to run a die down it before being sure what the thread was. Seems tomorrow’s job is making a new handle for the toolpost. I got the lathe brand new about 6 years ago so it’s is likely just wear and tear on it it does get used a lot.
Neil Wyatt03/02/2018 11:23:47
19226 forum posts
749 photos
86 articles
Posted by Matt Martin on 02/02/2018 23:49:18:
Easy to overtighten - a greased washer (some folks use a thrust bearing) on top of the toolpost can help, but its thickness will affect where the 'tight' position is.
Wout Moerman03/02/2018 11:27:56
57 forum posts
The greased washer sounds like a good trick. Best to make it 1.5 mm thick if the tight position is critical. I'll try one before ordering a roller bearing which I planned to do.
Howard Lewis03/02/2018 11:40:58
7227 forum posts
21 photos
Might be worth doing a dry run to find the "locked" position, and then to adjust the thickness of the washer so that the locked position does not leave the handle over the workpiece. (One of my idiosyncrasies!)
Neil Wyatt03/02/2018 13:57:27
19226 forum posts
749 photos
86 articles
I skimmed the base of the handle.
N.
