Colchester oiling points help
choochoo_baloo20/01/2018 01:09:17
282 forum posts
67 photos
I recently took delivery of a roundhead Colchester Master lathe.
Being fairly new to machine tool 'ownership' I'm not sure what to do with these button type oiling points? Do I need an oil gun?
I have only owned a Myford ML7, which has the raised nipples that take a pump action oil gun.
Also, is an oiler in such a condition inoperable?
Thanks in advance.
thaiguzzi20/01/2018 03:45:05
704 forum posts
131 photos
That's buggered. And not std issue. New imperial ball oilers available from RDG and metric versions from Arc Euro. Not expensive.
Normal oil can for lube.
the artfull-codger20/01/2018 04:40:59
304 forum posts
28 photos
My students got the same oilers as that one I just use a pump oil can.
not done it yet20/01/2018 07:12:35
7517 forum posts
20 photos
When i wanted a load of oilers I got them from the nipple shop. Not sure how they compare to the above suppliers on price/quality, but were fine for my lathe.
choochoo_baloo20/01/2018 19:30:45
282 forum posts
67 photos
Thanks chaps. How should I remove said oiler? I assume they are just a press fit in plain holes?
the artfull-codger20/01/2018 20:43:43
304 forum posts
28 photos
I just made tapered plugs for mine leaving the original oiler's in as per your picture ,that was over 30 yrs ago.
Jon20/01/2018 21:03:38
1001 forum posts
49 photos
Op's piccy is standard issue nothing wrong with it same as my Harrison.
Cross slide i have one nipple open, so put finger over as i pump the carriage plunger.
Just use an oil can press in then squirt, job done.
Other areas do have a ball and need same oil can pressure or wont feed in.
thaiguzzi21/01/2018 05:26:36
704 forum posts
131 photos
Really? Never seen a red ball oiler like that on all the Colchesters I worked on. Where's the ball? Anodized red aluminium?
Posted by Jon on 20/01/2018 21:03:38:
Stuart Bridger21/01/2018 10:24:41
566 forum posts
31 photos
My 1963 Chipmaster has the same oilers.
Jon21/01/2018 17:42:25
1001 forum posts
49 photos
Posted by thaiguzzi on 21/01/2018 05:26:36:
Reds highlighted to show!
Heres the balls under spring pressure perfectly standard issue. Another under DRO slide raised like OP's!
Again
Ball missing, it fell out meaning an open hole.
thaiguzzi22/01/2018 03:02:12
704 forum posts
131 photos
Ah, crafty - red highlighted. My apologies, photos below show stock type ball oilers indeed.
Posted by Jon on 21/01/2018 17:42:25:
Again
