Beth Ashby MyTimeMedia | 11/01/2018 11:54:32 |
7 forum posts | Just for fun we thought it might be nice to feature one of your models in our Facebook cover spot so we’re throwing it open for you to send us a maximum of two images that depict your favourite model in action. Post on this thread but do bear in mind that we’re after realistic running shots only please – no gardens and no workshops in this one. The website will only allow low res images but we'll contact the winner for a high res version in the fullness of time. Twist our arm and we might even be persuaded to give away a free subscription. We're nothing if not very generous! |
mechman48 | 11/01/2018 12:29:29 |
![]() 2947 forum posts 468 photos | |
FMES | 11/01/2018 12:35:56 |
608 forum posts 2 photos |
realistic running shots? |
mechman48 | 11/01/2018 13:27:15 |
FMES | 11/01/2018 15:26:47 |
608 forum posts 2 photos | That made me look twice as to how the V10 was running with the valve chest cover removed - good trick. Lofty |
JasonB | 11/01/2018 15:39:25 |
![]() 25215 forum posts 3105 photos 1 articles | Beth, do they have to be action shots? Usually it is easier to see the model if the flywheel and other moving parts are not blurred or if taken at a fast enough speed to freeze the moving parts then the engine will look stationary anyway. Or are you only after a loco or traction engine with smoke billowing out the chimney? |
Beth Ashby MyTimeMedia | 11/01/2018 21:48:45 |
7 forum posts | Posted by JasonB on 11/01/2018 15:39:25:
Beth, do they have to be action shots? Usually it is easier to see the model if the flywheel and other moving parts are not blurred or if taken at a fast enough speed to freeze the moving parts then the engine will look stationary anyway. Or are you only after a loco or traction engine with smoke billowing out the chimney? Hi Jason, I think we can be a little relaxed on the 'action' the idea was primarily to find some 'animated' shots that suggest movement. Smoke would qualify as would any other moving part. Having said that, if we're presented with a beautifully shot image of a gorgeous or atmospheric loco, traction engine, stationary engine (or whatever) at rest, it's going to be very hard to ignore. Does that help? |
mechman48 | 11/01/2018 22:02:49 |
![]() 2947 forum posts 468 photos | Posted by *.* on 11/01/2018 15:26:47:
Edited By mechman48 on 11/01/2018 22:06:22 |
