Velocette timing gears
Graham Williams 5 | 31/12/2017 10:45:53 |
![]() 98 forum posts 9 photos | Have been asked if I can make a new magneto drive gear for a Velocette motorbike, it's a M series alloy motor, to replace a fibre type gear in the timing gearchain. Does anyone know the gear specs, PA, DP and the teeth are angled I believe. |
Emgee | 31/12/2017 11:26:47 |
2610 forum posts 312 photos | Hi Graham, if gear information is not forthcoming you can always measure another gear in the train to help calculate the DP as a starting point, if the original mag drive gear is available but striped of teeth you should still be able to count the number of teeth.. Emgee |
John MC | 31/12/2017 12:28:47 |
![]() 464 forum posts 72 photos | 92T 32DP, 20deg. PA, 16deg. LH helix. Top dia. 3.063", Ptich dia 3.00", Root dia 2.922", all+0 -0002". Hope this helps. John Edited By John MC on 31/12/2017 12:36:33 |
Hopper | 31/12/2017 12:43:18 |
![]() 7881 forum posts 397 photos | Once again, the breadth and depth of knowledge on this forum leaves me gobsmacked. Well done and Happy New Year. |
larry Phelan | 31/12/2017 14:02:36 |
![]() 544 forum posts 17 photos | Hopper,I second that !! |
Graham Williams 5 | 31/12/2017 16:45:44 |
![]() 98 forum posts 9 photos | Thank you John MC, number 2 cutter available at RDG as I don't have 32DP, he'll have to cough for the cost of that if he says OK. You must be a Velocette motorbike engineer to have that knowledge to hand?????. I'm with Hopper and Larry Phelan but it's an old saying if you don't ask you don't (in this case find out).Happy New Year everyone. Cheers Graham |
John MC | 31/12/2017 18:00:49 |
![]() 464 forum posts 72 photos | Graham, rather than making a gear why not buy a manual AR gear and modify that to carry the AT device? Not easy but you will be using a gear with properly generated teeth rather than the less than adequate formed teeth. John |
Graham Williams 5 | 31/12/2017 18:41:52 |
![]() 98 forum posts 9 photos | John. Yes that would be a better approach, Just did ebay search but nothing there then went onto Velocespares site, 2 listed there, a lightened one? + another which is listing 11 degree angle, are there 2 different angles used on the gear (depending on model/year?) then? Graham. |
duncan webster | 31/12/2017 19:43:23 |
5307 forum posts 83 photos | Can someone explain? 92 t at 32 dp should be 2.875" pcd. If I divide by the cosine of the helix angle I still get 2.991" not 3" as JohnMC post. (I'm sure he's right by the way) |
Baz | 31/12/2017 20:21:47 |
1033 forum posts 2 photos | I am most probably wrong but I thought that RDG gear cutters are 14.5 PA |
not done it yet | 31/12/2017 20:26:45 |
7517 forum posts 20 photos | Duncan, Maybe you are not adding 2 to the tooth count before dividing by 32? Or maybe these gear calls are too complicated for me!
Edited By not done it yet on 31/12/2017 20:30:04 |
Graham Williams 5 | 31/12/2017 20:46:17 |
![]() 98 forum posts 9 photos | Baz, missed that, 14 1/2 degrees is what RDG have, but CR Tools in Sheffield list both 14 1/2 and 20 degree PA, probably very expensive. Given the suggestion by John to modify a 'manual' magneto drive gear, that appeals the most, will have to ask if the angle on the one on the motorbike can be checked so as to completely eliminate the 11 degree mentioned on the other web site. Cheers Graham. |
John MC | 01/01/2018 09:24:40 |
![]() 464 forum posts 72 photos | Posted by Graham Williams 5 on 31/12/2017 18:41:52:
John. Yes that would be a better approach, Just did ebay search but nothing there then went onto Velocespares site, 2 listed there, a lightened one? + another which is listing 11 degree angle, are there 2 different angles used on the gear (depending on model/year?) then? Graham. I believe that Veloce used spur gears in the early M series, then 11deg helix before finally settling on the 16deg helix angle The gear dimensions I have given will fit the Venom and Viper models, You could try Grove Classic Motorcycles for a gear.
duncan webster | 01/01/2018 12:19:03 |
5307 forum posts 83 photos | Posted by not done it yet on 31/12/2017 20:26:45:
Edited By not done it yet on 31/12/2017 20:30:04 you don't add 2 to get the pcd, that's to get the OD |
