What is the difference ?
Brian John | 25/11/2017 01:35:53 |
1487 forum posts 582 photos | What is the difference between CCGT 060202 and CCGT 060204 ? Can either be used for machining brass, bronze, aluminium and silver steel ? Are they the equal in size and shape so that they will fit in the same holder ? NOTE : I thought I had asked this question before but I could not find it using the search box.
Edited By Brian John on 25/11/2017 01:41:51 |
I.M. OUTAHERE | 25/11/2017 02:00:26 |
1468 forum posts 3 photos | The last two numbers designate the radius 02 = 0.2mm 04 = 0.4 mm . Other than that they are the same and will fit the same holder , i don't see an issue with machining the materials you listed . http://www.mitsubishicarbide.com/en/technical_information/tec_turning_tools/tec_turning_insert/tec_turning_guide/tec_turning_identification There are dozens of carbide insert charts on the internet and i know that kyocera and sandvik both have apps you can put on your phone or ipad etc . Edited By XD 351 on 25/11/2017 02:15:49 |
JasonB | 25/11/2017 07:33:05 |
![]() 25215 forum posts 3105 photos 1 articles | For your small lathe I would go with the 02 as the smaller tip radius will be more suited to the shallow cuts you are limited to taking. |
Douglas Johnston | 25/11/2017 09:49:49 |
![]() 814 forum posts 36 photos | The 04 tip will be a bit more robust and may last longer, but I also like an 02 tip on my small lathe (Myford Speed 10 ). The small radius also makes it possible to produce nice sharp internal corners. |
fizzy | 25/11/2017 10:17:34 |
![]() 1860 forum posts 121 photos | I use the 202 for copper boiler tube and find it 'sharper' than the 204 and less likely to grab. I have broken a few inserts but you have to do something pretty brutal to damage them. I buy the very cheap ones and they perform perfectly on my slow running L5, so much so that I now use nothing else. |
