1/4 BSP PIPE
ray jones 122/11/2017 13:19:38
54 forum posts
29 photos
HI
I am trying to locate a short length of 1/4 BSP metal pipe.
A minimum length of 200mm up to 300/400 mm would be ideal ( or longer)
I have tried all the usual sources.
Any suggestions to locate a piece, new or used ,
would be appreceiated
Many thanks
ray
Edited By ray jones 1 on 22/11/2017 13:20:02
Edited By ray jones 1 on 22/11/2017 13:24:30
JasonB22/11/2017 13:26:55
If you don't mind the ends already threaded then plenty on e-bay such as this
HOWARDT22/11/2017 14:54:07
1081 forum posts
39 photos
What material and wall thickness.?
Ian S C22/11/2017 15:25:32
7468 forum posts
230 photos
Stainless steel (304) 200 mm long, size not listed, but appears reasonable.
Ian S C
JasonB22/11/2017 16:13:58
Does 1/4" pipe come in more than one wall thickness. To me it is 1/4" bore and the correct OD to suit 1/4" BSP what other size do you two need?
S.D.L.22/11/2017 16:46:34
236 forum posts
37 photos
Posted by JasonB on 22/11/2017 16:13:58:
There is various schedules (wall thickness)
The OD is constant (10.29mm )the wall is described by schedule 10s 40, 40s, 80, etc
Such is the fun between pipe and tube
Steve
JasonB22/11/2017 17:05:30
Think you would have a job threading an pipe with 10.29mm OD 1/4 BSP, don't know about you but my 1/4" BSP die would slip straight over that!
ray jones 125/11/2017 03:14:44
54 forum posts
29 photos
Thank you for all of the replies. Item now located.
