Brian Rutherford | 08/11/2017 12:08:46 |
109 forum posts 3 photos | Facing a 6x5 plate this morning from the centre outwards using the powered cross feed and i noticed it had stopped cutting. The leadscrew has stopped turning and the lever to engage has jammed. The cut i was takings was only 2 or 3 thou. No bumps or bangs. Ive fiddled with the knobs but can't free it. Any pointers on where to start stripping it ?
Tia
Brian |
Mick B1 | 08/11/2017 12:40:58 |
2444 forum posts 139 photos | You've most likely run out of slide movement and forced the crosslide up against the handwheel casing. I've done that, in both directions. If the main leadscrew's stopped, the shearpin (1/8" brass) inside the headstock end of the spring-steel coiled cover is probably broken, but not before it tightened the crosslide leadscrew against the handwheel casing as above. When it happened to me I just muscled it loose again and retightened the crosslide leadscrew nut in the middle of the top surface. Then replace the shearpin and you should be able to carry on with no significant damage. |
Mick B1 | 08/11/2017 13:38:48 |
2444 forum posts 139 photos | If it feels too risky to force the feed lever out of engagement, you might need to loosen or remove the block where the engagement quadrant (really a partial gear) rotates. In one case I think I had to loosen off the guideplate with the zigzag slot in it that controls engagement lever movement. If all else fails, phone Warco. They may not know exactly what to do in a particular case, but their advice has been helpful to me in the various troubles I've got myself into. Edited By Mick B1 on 08/11/2017 13:41:26 |
Brian Rutherford | 08/11/2017 13:48:31 |
109 forum posts 3 photos | Didn't run out of travel still got 65mm to go. What I did do was cut the motor as the grub screws on the toolpost caught the guard . Switched it back on without disengaging the feed. Oops.
Mick B1 | 08/11/2017 14:49:36 |
2444 forum posts 139 photos | Posted by Brian Rutherford on 08/11/2017 13:48:31:
Didn't run out of travel still got 65mm to go. What I did do was cut the motor as the grub screws on the toolpost caught the guard . Switched it back on without disengaging the feed. Oops. Can't visualise how that would jam the crosslide. If mine still had its guard, I think the toolpost screws - if we're talking about the same screws - would just have pushed it up and out of the way, maybe cutting the motor, but with no obvious consequences on restarting. Are you sorted now? |
Brian Rutherford | 08/11/2017 14:51:38 |
109 forum posts 3 photos | My mistake Mick b1. I did run out of travel. And jammed the slide as you said. |
Brian Rutherford | 08/11/2017 16:06:22 |
109 forum posts 3 photos | Lead screw will now turn but I think the shear pin has gone. I have taken the block off that the traverse lever fits into. The worm gear was stuck but moves in and out now. Just can't turn the cross slide handle although it moves a little bit. |
Mick B1 | 08/11/2017 16:06:44 |
2444 forum posts 139 photos | Tried slackening off the two capscrews securing the crosslide leadscrew/handwheel bearing housing? Could the crosslide leadscrew shearpin have fallen partway out so as only to let the handwheel rotate a few degrees? I had that happen too, but it ended up falling into the apron gearbox and jamming pinions in that! Edited By Mick B1 on 08/11/2017 16:10:05 |
Brian Rutherford | 08/11/2017 16:54:47 |
109 forum posts 3 photos | Will have a look later. It seems when I turn the Lead screw manually the handwheel turns dificult wvithout a C spanner for the nut . Can't get it out of gear though. I will put the block back tonight after tea and see how it goes |
Brian Rutherford | 08/11/2017 16:54:49 |
60019 | 08/11/2017 17:22:50 |
24 forum posts 4 photos | If it's any consolation, you're not the first and I am sure you will not be the last.
This thread may help **LINK** |
SillyOldDuffer | 08/11/2017 17:45:19 |
10668 forum posts 2415 photos | Assuming the shear pins are OK, try spinning the chuck backwards by hand . (Not under power.) With luck the mechanism will back off enough to release the lever. Dave |
Mick B1 | 08/11/2017 17:45:39 |
2444 forum posts 139 photos | Posted by 60019 on 08/11/2017 17:22:50:
This thread may help **LINK** You also learn to check as a matter of course that the whole cut's within the range of movement, and that you don't wander off and get drawn into something else while it's running. You also learn to recognise the change in motor note as the feed runs into obstruction. Neverthless it's happened to me two or three times. The worst one was longitudinal feed with a locked saddle - that bent the drive pinion against the bed rack, making a very tight spot about every third turn of the saddle handwheel. But you can actually bend the pinion straight again with a standard crowbar! But for all that, the lathe is still as accurate as ever and does good work nearly every day. |
Brian Rutherford | 08/11/2017 17:50:30 |
109 forum posts 3 photos | Need to knock the shear pin out of the Lead screw. Is just a hammer and punch. Seems pretty tight to me |
Howard Lewis | 08/11/2017 18:37:36 |
7227 forum posts 21 photos | If you have a positive drive into the Apron, for longitudinal travel, but none to the Cross Slide, it looks as if you have sheared something within the Apron. If the Apron is like that on the Warco BH600 and its clones, the drive is taken from the worm into a gear which has a multi tooth dog clutch on each side. This slides to and fro, to drive gears for either the longitudinal traverse, or the Cross Slide. It is possible that this is pinned to the shaft, and that the pin has sheared (When I jammed up my BL12 - 24 and bent the pinion shaft, I was lucky in that the damage was confined to the longitudinal traverse pinion and shaft, so did not investigate this area). The article in MEW 254 includes a small view of the Apron from above, ready for reinstallation. If you would like file of this, of about 4Mb, PM me. I had already replaced the steel rollpin in the drive to the feedshaft with a 5mm brass pin, but the jam up did not shear it, so it now has a 2.5mm drilling down the centre, to weaken it. You may wish to do the same, in the hope that, next time, it will fail and prevent greater damage. Howard . Edited By Howard Lewis on 08/11/2017 18:39:19 |
Brian Rutherford | 08/11/2017 20:14:36 |
109 forum posts 3 photos | Thanks to all for your replies. Special thanks to Mick b1 for his advice and the link. Too tired to do much tonight so will leave it till morning as I don't want to make it worse. First job will be to remove the shear pin in the Lead screw, so far it's resisted all attempts with a hammer and punch so probably best to try to remove the Lead screw from the housing. Will keep you posted
Thanks Brian |
Mick B1 | 08/11/2017 20:32:58 |
2444 forum posts 139 photos | IIRC when I did this I removed the tail-end leadscrew bracket and unscrewed the vertical capscrews securing the apron to the saddle. Then you should be able to pull the leadscrew out of the sleeve at the headstock end and remove apron and leadscrew as a subassembly. Keep it vertical so as not to spill all the oil. |
Howard Lewis | 08/11/2017 20:54:01 |
7227 forum posts 21 photos | It is possible that the shear pin has sheared and then jammed again, after some rotation of the driving shaft. Is it possible to start drilling it? This might conform/deny this theory, (drill part way and try to look down hole. Should be no steel shaft visible at bottom of hole. If there is, try rotating the shaft 180 degrees and drill out the brass ,from the other side. With a bit of luck you can then remove the shaft from the drive, allowing you drive /drill out the remnant from the drive. Howard |
Stuart Riddell | 09/11/2017 07:47:45 |
![]() 15 forum posts | This may be a daft question, from a complete novice, but can the lathe still be operated without the shear pin in place. I am just looking at a WM250V and am assuming it has one of these or do all modern lathes have it |
Mick B1 | 09/11/2017 08:15:43 |
2444 forum posts 139 photos | Posted by Stuart Riddell on 09/11/2017 07:47:45:
This may be a daft question, from a complete novice, but can the lathe still be operated without the shear pin in place. I am just looking at a WM250V and am assuming it has one of these or do all modern lathes have it Yes it can, but the leadscrew won't be turned by the headstock geartrain, so there'll be no power feed for turning, facing or screwcutting. WM250V has one for the main leadscrew just in front of the headstock 'bulkhead', and one for the crosslide leadscrew just behind the bearing housing. Almost any properly-designed lathe will have these, modern or not. |
