Malcolm Farrant | 08/11/2017 10:27:37 |
102 forum posts 3 photos | I have completed my Front Wheels,, Flywheel, and Chimney, and am now tring to concentrate on the Boiler, but I have a problem.- I can find no detail in either the drawings or in L.C.Masons book as to the verticle position of the Firewhole Ring. I know it is fitted central in the Verticle axis, but at what distance from either the top or the bottom of the Plate. Equally I presume this, when finished will then link up with the Backhead - (am i correct in that thinking ?.) No doubt there are amny of you out there who can give me details of the measurement I seek. When I have eventually completed the boiler I will post photos of where I have got to. In anticipation....MANY THANKS
roy entwistle | 08/11/2017 10:56:58 |
1716 forum posts | Malcolm According to my copy of Mason's book page 18 the centre of the fire hole ring is 2 1/16 inches from top of boiler Roy |
Brian Abbott | 08/11/2017 12:35:00 |
![]() 523 forum posts 95 photos | Hello. Based on my sums, if you look at the section drawing of the boiler. 4.5” from the top of the outer rapper to the bottom of the bulkhead. |
Malcolm Farrant | 08/11/2017 14:32:50 |
102 forum posts 3 photos | Hello Roy, and Brian, Thank yiou both for your replies. Roy I am more than ever confused, as I have had another look at page 18, and also read the original Me magazine article and can find no mention of 2 1/6" !!! Brian, thanks for your calculation ity does seem that within a smidge it does not matter. I find dealing with imperial measurements is confusing . Therefore I tend to convert the Imperial to metric ( I have a big chart as a crib sheet). I will fiddle about with both your ideas and proceed from there Best wishes to you both Malcolm |
Brian Abbott | 08/11/2017 14:50:09 |
![]() 523 forum posts 95 photos | Does this help ? |
Dave Halford | 08/11/2017 16:03:14 |
2536 forum posts 24 photos | Looks just like my copy too |
JasonB | 08/11/2017 16:11:10 |
![]() 25215 forum posts 3105 photos 1 articles | And mine, try folding the page open a bit more as the dim is close to the spine. |
