nvr?? switch
mark smith 2029/10/2017 13:50:15
682 forum posts
337 photos
Hi,
I have this dismembered Perform brand  cheap wet and dry grinder ,im wanting to use it just to attach some diamond 6" flat lapping discs i have . Problem is the switch has decided to stop working.
It powers on but as soon as you take your finger off the start switch it stops.
I was wondering if this is the right switch from axminster?? is there cheaper anywhere?
dimensions of cut out are slight less on the axminster replacement .The original switch is around 42-43mm x 27mm. There is nothing written on the broken switch . The grinder is 250 watts.
Edited By mark smith 20 on 29/10/2017 13:50:31
Edited By mark smith 20 on 29/10/2017 13:56:25
not done it yet29/10/2017 14:15:34
7517 forum posts
20 photos
The last NVR switch I bought was from an epay seller. I didn't buy the cheapest available, but it was less than that one. Works OK.
Frances IoM29/10/2017 14:24:28
1395 forum posts
30 photos
I've used the Axminster switch on a grinder without problem - it used to be quite a bit cheaper when I bought it - you can certainly get ones with the same (?standard) fitting for about half that price - often these cheaper models have the additional feature of a link that allows wiring in other safety switches eg gear covers in lathes
mark smith 2029/10/2017 15:16:08
682 forum posts
337 photos
Thanks for the replies so the specs on the axminster one will work fine on the 1/3hp grinder ??
Nicholas Farr29/10/2017 15:35:42
3988 forum posts
1799 photos
Posted by mark smith 20 on 29/10/2017 15:16:08:
Hi Mark, yes, provided that you don't have an emergency stop or other fail safe switches to wire in.
Regards Nick.
Edited By Nicholas Farr on 29/10/2017 15:39:14
John Rudd29/10/2017 15:37:16
1479 forum posts
Q answered.....
Edited By John Rudd on 29/10/2017 15:38:17
mark smith 2029/10/2017 16:06:59
682 forum posts
337 photos
Ok thanks
