lug lord | 24/10/2017 16:16:26 |
![]() 60 forum posts 20 photos | Just ground myself a really nice facing tool for plastic very sharp etc and when i took it out of my tool post it was broken in 2 what would cause this is the tool post uneven am i tightning the screws too much or is it just a very old hss tool piece probably older than me maybe been dropped on the floor any ideas thanks |
David Standing 1 | 24/10/2017 17:11:30 |
1297 forum posts 50 photos | What sort of tool post is it? Was there swarf under one end of the tool? A photograph would help.
Edited By David Standing 1 on 24/10/2017 17:37:54 |
not done it yet | 24/10/2017 17:29:53 |
7517 forum posts 20 photos | The position at which it fractured should give you some indication of the likely cause.
If not a straightness of holder problem, it could be caused by tightening down beyond any packing pieces. While the tightening screws do not need to be extreeemly tight, over-tightening should more likely damage the screws/threads of the holder. |
Mick B1 | 24/10/2017 17:42:26 |
2444 forum posts 139 photos | I've done that to a 1/4" square bit when I tightened all 3 toolpost screws down onto it, but had forgotten that the packing only extended under the front 2. Didn't know I'd done it till I took the tool out. |
lug lord | 24/10/2017 18:04:32 |
![]() 60 forum posts 20 photos | Its a 4 tool post myford super 7 i think it might have been swarf under the tool maybe as i broke 2 tools one after another |
David Standing 1 | 24/10/2017 18:06:35 |
1297 forum posts 50 photos | Always brush your tool holder out before putting a tool in! But you know that now......... |
David Standing 1 | 24/10/2017 18:08:01 |
1297 forum posts 50 photos | By the way, with my reply to your RDG thread, it isn't 'pick on lug lord' day, honest |
SillyOldDuffer | 24/10/2017 18:49:08 |
10668 forum posts 2415 photos | Posted by lug lord on 24/10/2017 16:16:26: ... or is it just a very old hss tool piece probably older than me maybe been dropped on the floor any ideas thanks Are you sure the metal is HSS? I wonder if you have tool-steel - it's more brittle. Dave |
Mike Poole | 24/10/2017 19:00:08 |
![]() 3676 forum posts 82 photos | I was taught to put a piece of packing between the screws and the tool bit to minimise any tendency to a point contact. Mike |
lug lord | 24/10/2017 19:08:36 |
![]() 60 forum posts 20 photos | Posted by SillyOldDuffer on 24/10/2017 18:49:08:
not sure there very old tools for sure came in an old wooden cigar box ian
Hopper | 25/10/2017 05:52:32 |
![]() 7881 forum posts 397 photos | Posted by Mike Poole on 24/10/2017 19:00:08:
I was taught to put a piece of packing between the screws and the tool bit to minimise any tendency to a point contact. Mike Now there's a good tip. I learn something new on this site every day. |
lug lord | 25/10/2017 10:13:33 |
![]() 60 forum posts 20 photos | Posted by Hopper on 25/10/2017 05:52:32:
I was taught to put a piece of packing between the screws and the tool bit to minimise any tendency to a point contact. Mike Now there's a good tip. I learn something new on this site every day. Cheers for advice in future I will use a thick shim on the top to stop the point of the screws on the tools and make sure no swarf on my tool post thanks ian |
SillyOldDuffer | 25/10/2017 17:10:04 |
10668 forum posts 2415 photos | Posted by lug lord on 25/10/2017 10:13:33:
... ... and make sure no swarf on my tool post thanks ian Not just on the tool-post. Swarf goes everywhere it's not wanted. D*** stuff is a pain in the rear-end, sometimes literally! Well worth keeping chucks and leadscrews etc clean with a toothbrush. In theory I wipe off bearing surfaces like tapers and chuck backs every time I change tool. (In practice I often forget but that's a different problem.) Quite small bits of swarf in the wrong place can throw accuracy off as well as cause damage. Dave |
