Michael Checkley | 21/10/2017 11:10:19 |
![]() 121 forum posts 66 photos | I'm investigating bringing some machining back in house (actually back to the UK) but we would need a gap bed lathe capable of turning a diameter of ~900mm. So far I have been searching for both new and used machines, as a DRO will be used I'm not worried about it being metric or imperial. Material being machined is aluminium and as the part is a ring only about 150mm travel is required. Depth of part is about 100mm. Not much luck so far and some distributors swapping between radius and diameter for the swing over gap isn't helping much. Any help or suggestions of brand to look for would be much appreciated. |
Andrew Johnston | 21/10/2017 11:10:34 |
![]() 7061 forum posts 719 photos | Vertical borer? Would be more compact, but may not be a fast enough cycle time. Andrew Edited By JasonB on 21/10/2017 13:09:32 Edited By JasonB on 21/10/2017 13:10:17 |
Michael Checkley | 21/10/2017 11:12:54 |
![]() 121 forum posts 66 photos | Hi Andrew, Thanks, ill have a look in to a vertical borer, I think that is how they are being machined at the moment. I have asked admin to delete this thread as the title is wrong. not sure how my name got in there. Mike Edited By JasonB on 21/10/2017 13:10:40 |
Journeyman | 21/10/2017 11:16:10 |
![]() 1257 forum posts 264 photos | This is called a vertical lathe may be the same as a borer, could be the tool for the job? John Edited By JasonB on 21/10/2017 13:10:59 |
Michael Checkley | 21/10/2017 11:52:29 |
![]() 121 forum posts 66 photos | Vertical borer looks interesting especially if we could fit a drilling spindle to the tool post as there are some holes to drill on a PCD Edited By JasonB on 21/10/2017 13:11:22 |
Mick B1 | 21/10/2017 12:09:22 |
2444 forum posts 139 photos | Back in the 70s I was turning big cable reel components for the Coal Board on a Binns & Berry with about a metre or more swing into a wide bed gap, but a max between centres of maybe 2M. I came to think well of the machine, but I can't remember any model no. I think it was already quite old back then. Edited By Mick B1 on 21/10/2017 12:14:20 |
mark smith 20 | 21/10/2017 12:30:53 |
682 forum posts 337 photos | sound like you need a facing lathe of some kind such as: or has been previously mentioned on the other thread: Edited By mark smith 20 on 21/10/2017 12:40:42 |
Michael Checkley | 21/10/2017 20:38:54 |
![]() 121 forum posts 66 photos | A Binns and Berry machine would certainly do the job, not sure we have the floor space for a machine that long though. |
Clive Foster | 21/10/2017 22:21:05 |
3630 forum posts 128 photos | Vertical lathe was what was used at RARDE / DERA / DRA for such jobs. As I recall matters the guy who drove it didn't consider it unreasonably slow but never saw it in use myself. Setting up on a facing lathe will be a PIA. Not a one man job. Probably crane involved too. Much easier to slide around on the horizontal faceplate of a vertical lathe. Clive. |
