Weird triple flute drills
Rainbows20/10/2017 16:16:40
658 forum posts
236 photos
Got a big ole bunch o big drills. Going to move the MT3 ones on since my machines are MT2. Found two odd ones in the batch though. Anyone know what they might be for?
1 5/32" dormer
63/64" dormer
Ian Parkin20/10/2017 16:21:21
1174 forum posts
303 photos
I’ll have some of your mt 3 drills rainbows?
What sort of price you looking at? I’m in sheffield S7 where are you?
Ian
david sanderson 320/10/2017 16:30:10
17 forum posts
i think they are core drills for drilling castings
Clive Foster20/10/2017 16:31:54
3630 forum posts
128 photos
Three flute drills are said to be better at opening out holes than two flute. Especially cored ones in castings which are pretty much inevitably less than accurate unless high end pressure techniques are used. Probably a stability issue.
Clive.
ega20/10/2017 16:37:31
2805 forum posts
219 photos
Core drills need a pilot hole but are otherwise excellent. I think they come in four flute style as well.
SillyOldDuffer20/10/2017 16:44:47
10668 forum posts
2415 photos
I read about multi-flute twist drills recently whilst researching better ways to drill straight deep holes. I think it was on the web. From memory, they were invented by Brown & Sharp at the same time as the conventional twist drill. They cut rounder holes than a two-flute and are less inclined to wander off axis. The downside is they are expensive to make and easier to break. The more flutes the weaker they get.
They don't seem to be easy to buy. I did find this example.
Neil Wyatt20/10/2017 16:52:07
19226 forum posts
749 photos
86 articles
Posted by SillyOldDuffer on 20/10/2017 16:44:47:
Blimey I would say that's cheap for Guhring!
geoff adams20/10/2017 17:26:38
214 forum posts
207 photos
core drill to drill cast holes to true up used them on cnc mill back in the 80s on precision barometers when I worked
for negretti aviation
MW20/10/2017 18:17:42
2052 forum posts
56 photos
Indeed this is a core drill my friend, and they're quite unusual so i'd hold onto them, they are quite expensive and limited to purchase.
They are the tool for opening out holes already drilled, hence the blunted end. The idea is that the hole ends up being less "triangular" than the variety twist drills often do and therefore more circular, the more flutes you've got the better it gets, (not sure how much better).
Michael W
ega20/10/2017 18:23:03
2805 forum posts
219 photos
..."The more flutes the weaker they get."
I would have been inclined to agree but one authority points out that "The end of the [core] drill ... does not come to a point, as in the case of the ordinary drill. For this reason the web can be made thicker, so that a stronger drill results."
Nick Hulme20/10/2017 18:36:24
750 forum posts
37 photos
Two flute drills have a tendency to cut a tri-lobal hole, three flute drills don't have the same tendency.
Rainbows20/10/2017 20:35:33
658 forum posts
236 photos
Posted by Ian Parkin on 20/10/2017 16:21:21:
Ian
Im at S2, near the football stadium.
Im thinking of £4 for the good drills, £3 for the drills that need a slight touch up and £2 for the ones where it needs a fair regrind. Got 6 of the first, 2 of the middle and 2 of the last. Mostly Dormer with a Cleveland and a Guhring with it. Could send an exact list of the sizes if you are interested?
Ian Parkin20/10/2017 21:33:57
1174 forum posts
303 photos
Let me have your number so I can call you I,m probably 200 yards from You or so
Raymond Anderson21/10/2017 05:39:28
785 forum posts
152 photos
Neil, I would agree that the price of the advertised drill you linked to would be cheap for Guhring, but... the drill advertised is Walter [ Titex ] and as prices go are more expensive than even Guhring. It is sold as new but must be old stock, as I checked the Walter prices and the drill is from a series that is mega spendy. Certainly a specialized drill.
Cheers.
Ps, unless you meant  that would be cheap if it  "were " a Guhring
Edited By Raymond Anderson on 21/10/2017 05:41:06
not done it yet21/10/2017 06:31:26
7517 forum posts
20 photos
Buy 'em quick. They are cheap, even for normal Dormer drills!
Edited By not done it yet on 21/10/2017 06:31:54
Dinosaur Engineer21/10/2017 14:52:53
147 forum posts
4 photos
Have used 3 flute carbide in the past - they produce straight holes to reamer limits.
Swarf, Mostly!21/10/2017 15:02:11
753 forum posts
80 photos
Hi there, all,
Does anyone have any experience of, or comments on, the business of sharpening core drills?
Best regards,
Swarf, Mostly!
John Reese21/10/2017 16:07:15
1071 forum posts
I have a number of 3 and 4 flute core drills. I sharpen on the same equipment I use for 2 flute drills. In a pinch, they can be sharpened by hand. The clearance angle would be the same as on a 2 flute drill.
John Haine21/10/2017 16:45:38
5563 forum posts
322 photos
Core drills great for opening out holes to then bore out. They don't grap and turn funny shaped lobed holes. Well worth having.
