Hello All,
Trevor Harris12/10/2017 14:43:31
3 forum posts
Hello All,
Just to say hello and looking forward to tapping into this vast 'Knowledge base' and perhaps chipping in with my two pennies worth every now and then.
Writing this post I have just realised that I have been in engineering 47 years both as employment and as a leisure pursuit. Though an experienced machinist I consider myself a novice in my main interest of clocks. The current project is a John Wilding 8 day weight driven clock. I have made plates and pillars main shaft barrel and pendulum. I also have an interest in general machining, making jigs and fixtures to help a project along.
Apologies if a similar post appears twice, I clicked on code of conduct and my draft thread disappeared!
Chris Evans 612/10/2017 18:56:27
2156 forum posts
Welcome along Trevor, I did my 50 years in engineering but am still learning and picking up hints here.
Neil Wyatt21/10/2017 16:11:40
19226 forum posts
749 photos
86 articles
Hello Trevor,
Sorry for the late welcome.
Trevor Harris23/10/2017 09:04:21
3 forum posts
Hi Neil,
No Worries about a late welcome. Just pleased to see model engineering still thriving. In Craftsmen of my generation the boundaries of engineering work and leisure were often blurred. If you did not have lathe in the shed at home projects were often done as 'Government Work' in the lunch hour away from the Foreman's eyes.
Trevor
Swarf, Mostly!23/10/2017 09:41:48
753 forum posts
80 photos
Posted by Trevor Harris on 23/10/2017 09:04:21:
Hi Neil,
SNIP
Trevor
I don't believe that the foremen were oblivious of the 'Home Office' jobs - after all, they hadn't always been foremen. As long as the 'Home Office' jobs were pursued with discretion they were classed as training exercises.
Best regards,
Swarf, Mostly!
Trevor Harris23/10/2017 10:28:04
3 forum posts
Hi Swarf, Mostly,
I think you were probably correct. I was a bit of skill in judging how far to push your luck! The bigger the project the harder it was.
Years ago I had a colleague making a Go- Cart for his son , The chassis was a team effort, welders, fitters and machinists being called in to help. It only just fitted under the bench, hidden by a dust sheet.
Trevor
Mike Poole23/10/2017 10:36:11
3676 forum posts
82 photos
I think everyone wants a "homer" done, I have done loads for for people from the top down, that is probably why a blind eye is turned because if they stop you doing a homer how can they ever ask for one?
Brian H23/10/2017 11:22:07
2312 forum posts
112 photos
They were called 'foreigners' where I started work and my first foray into model engineering was to use the Boxford lathe that we had in the aircraft parts inspection department to make a cannon using the plans in " The Anatomy of Nelsons Ships". I used one of the heat treatment ovens to produce a dark blued finish and the wooden parts were made from an offcut of the wood used to make high end kitchen units in another part of the factory.
ega23/10/2017 11:22:58
2805 forum posts
219 photos
I believe they were also called "rabbits" because when the foreman appears they go back in their holes.
Mick Henshall23/10/2017 11:28:19
562 forum posts
34 photos
This is true ega, "Rabbets"  was the term used in the RN
Mick
Mick Henshall23/10/2017 11:31:19
562 forum posts
34 photos
I am still getting these A things with a squiggle over the top in some of my posts and I don't know why
🤔 Mick
SillyOldDuffer23/10/2017 11:57:26
10668 forum posts
2415 photos
Posted by Mick Henshall on 23/10/2017 11:31:19:
🤔 Mick
Might be because the poster is using a touch screen rather than a proper keyboard. On an Android tablet a short tap on the 'keyboard' selects ordinary characters whilst a slightly longer tap gets an accented character. Whatever is causing it, It's not your fault!
clogs23/10/2017 12:50:56
630 forum posts
12 photos
trying to get the squiggles by design is the real problem with a "Querty" key board......hahaha......
clogs
Mike Poole23/10/2017 13:58:15
3676 forum posts
82 photos
The cheekyist homer I remember was a trailer, it was completely finished and at the time you could get a scrap ticket for a trailer load of wood so fill it with wood for £1 and drive out the gate.
