Neil Wyatt | 23/09/2017 21:28:02 |
![]() 19226 forum posts 749 photos 86 articles | Obviously not as strong as in metal, but stronger than you expect. This is a 30x30 x20mm deep block with a slightly tight M6 thread printed in. Using a spring balance and a lever to pull straight up it started to fail at 108kgf. That's nearly 240 pounds or considerably more than I weigh. |
jimmy b | 24/09/2017 07:02:28 |
![]() 857 forum posts 45 photos | Impressive. Is that PLA or AVE? Jim |
JasonB | 24/09/2017 07:38:21 |
![]() 25215 forum posts 3105 photos 1 articles | How far in is the screw, not too impressive if it is in the full depth of the block but if only 1D thats a bit better. |
Dave Martin | 24/09/2017 07:49:39 |
101 forum posts 11 photos | Interesting, thank you Neil. How was the block held - was it, say, below a plate with an M6 clearance hole in it - or was it in a vice? How did you get axial-only pull? Could you post an image of your test rig please? Dave |
Neil Wyatt | 24/09/2017 09:08:37 |
![]() 19226 forum posts 749 photos 86 articles | It was inserted by eight threads. The test rig was basically a 300mm bar with a 6mm hole 25mm from one end so the ratio of forces was 12:1, the block was held in a vice with another bar across the vice to provide a fulcrum level so the bar was pretty much level. I used a spring balance. I did other experiments with blocks under the vice jaws (not clamped) and 'hook' made from bar so the spring balance could pull up, but the maximum force that way was 75kgf. I got some very interesting results but they will remain confidential for now! |
Andrew Johnston | 24/09/2017 10:51:04 |
![]() 7061 forum posts 719 photos | I've not 3D printed threads, but have tapped them in plain holes. They were plenty strong enough for my application - trial run of my traction engine gear change mechanism. It would be interesting to see a comparison of printed versus tapped holes, both cut and roll formed. Andrew |
Neil Wyatt | 24/09/2017 12:18:34 |
![]() 19226 forum posts 749 photos 86 articles | Not sure it will make much difference as it's failure of the fill not the thread. |
Dave Martin | 24/09/2017 12:44:10 |
101 forum posts 11 photos | Posted by Neil Wyatt on 24/09/2017 09:08:37:
.......The test rig was basically a 300mm bar with a 6mm hole 25mm from one end so the ratio of forces was 12:1, the block was held in a vice with another bar across the vice to provide a fulcrum level so the bar was pretty much level. I used a spring balance. I did other experiments with blocks under the vice jaws (not clamped) and 'hook' made from bar so the spring balance could pull up, but the maximum force that way was 75kgf..... Neil, I would wonder how much compression of the test sample from the vice would affect things - would be intrigued if repeated with just a pair of bars with, say, 7mm holes - so the only force on the block was on its top surface? |
Neil Wyatt | 24/09/2017 13:58:03 |
![]() 19226 forum posts 749 photos 86 articles | I'm sure this may have had a negative effect by straining the fill. I think it is important that there's a larger area of unsupported top surface, just straining the thread is unrealistic and will give a misleadingly high result - I haven't had a thread strip before the fill let go. I will make sure there's a roughly 20mm circle clear around the fixing. I will repeat when I have PLA back in the printer, I'm using ABS at the moment. |
Robin | 24/09/2017 14:41:00 |
![]() 678 forum posts | If you were designing with 3D printing in mind would you not prefer a screw with a sharp helix around a cylindrical core? This, I presume, is to attach a 3D printed part to something with an existing thread... |
Andrew Johnston | 24/09/2017 15:04:35 |
![]() 7061 forum posts 719 photos | Posted by Neil Wyatt on 24/09/2017 13:58:03:
I think it is important that there's a larger area of unsupported top surface, just straining the thread is unrealistic and will give a misleadingly high result - I haven't had a thread strip before the fill let go. So why doe thes thread title refer to strength of threads when you're actually looking at the strength of the surrounding material? Andrew |
Neil Wyatt | 24/09/2017 15:47:32 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Andrew Johnston on 24/09/2017 15:04:35:
I think it is important that there's a larger area of unsupported top surface, just straining the thread is unrealistic and will give a misleadingly high result - I haven't had a thread strip before the fill let go. So why doe thes thread title refer to strength of threads when you're actually looking at the strength of the surrounding material? Andrew If we are getting into sophistry, I'm looking at the strength of 3D printed threads and I have discovered they are stronger than the bulk material. |
David Clarke 21 | 24/09/2017 16:56:40 |
4 forum posts 5 photos | I was recently working with a product designer using M6 bolts into 3D printed parts. Thinking that the strongest result would be to have a metal - metal thread, Helicoils were being inserted into the plastic parts. Unfortunately, they appeared to self-tap into the holes without needing to used the supplied tap to cut a thread first. The result was that on inserting the M6 bolt, the coil tried to extend to its design pitch which internally de-laminated the printed part, seriously (though not terminally) weakening it. Not visible from the surface, but recognisable by the creaking sound of the material splitting internally. Although this was the result of incorrect process, I imagine that simply self-tapping a machine screw could have similar results, especially if the metal thread pitch 'beats' with the layer thickness. David (long-time lurker from Nottingham) |
