Russ B | 20/09/2017 12:29:19 |
635 forum posts 34 photos | There are getting thrown out, but I see uses for them in the home workshop as lathe bed stiffeners/raisers to add a bit of extra mass - these would be sturdy enough to twist a bench top size lathe bed true if need be (up to Myford 7 / Boxford AUD sort of size) Obviously they could be used for all sorts of seriously heavy duty work, a bearing press is another good example. There is also a stack of 10+ slightly smaller section stub length around a few hundred mm long. Getting thrown in a skip this week or next, I could hang on to them for a little bit if need be. 2 painted grey U section RSJ 200x75, 12mm webs, 6mm thick across the 200mm width. Both 1050mm long. 1 unpainted 200x95, 15mm webs, 8mm thich across the 200mm width 1620mm long, flame cut at one end. any takers for one/all, must be collected from DN2 4SE area in Doncaster - all very heavy obviously. Edited By Russ B on 20/09/2017 12:31:31 |
Russ B | 20/09/2017 12:31:00 |
Antony Powell | 20/09/2017 13:43:05 |
![]() 147 forum posts 19 photos | I'll take them off you could collect on Monday on the way home from Birmingham Thanks Tony |
Antony Powell | 21/09/2017 08:21:32 |
![]() 147 forum posts 19 photos | Hi Russ can you message me the collection address & a contact number thanks Tony |
Russ B | 21/09/2017 09:46:34 |
635 forum posts 34 photos | Tony, sorry i think it's gone, someone local is collecting, I'll let you know if it falls through
Ady1 | 21/09/2017 09:50:10 |
![]() 6137 forum posts 893 photos | Looks seriously useful (drool) If you're cutting it up with a hand held angle grinder I have found that long straight lines work best with thick flat stock So I would go in the back, and cut a 1mm deep long channel across the width Then 2mm, then 3mm etc etc, (seems to be much easier than "going straight through" ) Once through the back you can lop the end bits easy peasy Edited By Ady1 on 21/09/2017 09:51:22 |
Neil Wyatt | 21/09/2017 22:55:46 |
![]() 19226 forum posts 749 photos 86 articles | 12" of that would be just the job to build a bespoke machine on like a gear hobber or a grinder. |
