JOHN BURNELL 1 | 10/09/2017 20:52:02 |
![]() 20 forum posts 9 photos | Still getting to grips with my cowells lathe, so the thing is i have been cleaning the unit up, so i got to the tailstock and realised it seemed to be jammed up ie not retracting and moving when you move the tailstock dial, so on some further messing around and to be honest using some brute force i have managed to completley destroy the threaded bar going through the centre snapped it in half, i think its a reverse type thread on it, my main question is what other tailstock will fit as it seems imposible to get any advice would be very apreciated.
regards john |
roy entwistle | 10/09/2017 21:01:48 |
1716 forum posts | Try contacting Cowells Roy |
JOHN BURNELL 1 | 10/09/2017 21:14:04 |
![]() 20 forum posts 9 photos | Does anybody have contact for Cowells? i have also heard that the tailstock off the ml7 is the same ? the tail stock has mt0 fitting i was thinking of trying to rig somthing up to move it back and forward till i come across somthing
john |
Nick_G | 10/09/2017 21:16:42 |
![]() 1808 forum posts 744 photos | .
Edited By Nick_G on 10/09/2017 21:19:19 |
Nick_G | 10/09/2017 21:18:02 |
![]() 1808 forum posts 744 photos | Posted by Nick_G on 10/09/2017 21:16:42:
. I have bad news and good news for you. Bad news is this is likely going to cost quite a bit of money to fix. Good news is. .......... It was not me that did it. Like Roy says contact Cowells as they are the only people likely to have spares as Cowells lathes tend to not get split for 2nd hand parts sale. Nick Edit :- for Cowells site **LINK**
JOHN BURNELL 1 | 10/09/2017 21:41:26 |
![]() 20 forum posts 9 photos | Is there any other machine with a very similar tail stock arangment ? as i said i have read in older threads that the ml 7 will fit, all is not lost as i can still use it for centering etc and in ref to drilling this is going to be my difficulty but as i only need to drill to re pivot my clock repairs i will aft to find a way to move the tailstock along, im begining to think the centre going through the tailstock something was wrong as the face plate does not fit either it is supposed to be m14x1.5 but on measuring the thread on the plate its 12mm
regards john |
Frances IoM | 10/09/2017 21:47:17 |
1395 forum posts 30 photos | I think the Cowell lathes continued to use the cut down 0MT used by Perris in his lathes (Cowells bought the firm after his death) - this is the small end of the 0MT taper and unless you make your own you need dig deep to buy off Cowells as any full length 0MT sticks well out of either head or tailstock - I think the drive rod is a LH 6mm x 1mm thread but again Cowells may have changed from Perris and I'm away from my workshop and manuals so can't check (might be worth posting a picture so others can see just what damage has been done) - this should be relatively easy to make tho LH dies are not cheap but anyone with a screwcutting lathe should be able to help you Edited By Frances IoM on 10/09/2017 21:47:51 |
JOHN BURNELL 1 | 10/09/2017 21:51:03 |
![]() 20 forum posts 9 photos | Thanks will do the thread is 6mm,
regards john |
Michael Gilligan | 10/09/2017 21:58:36 |
![]() 23121 forum posts 1360 photos | Posted by JOHN BURNELL 1 on 10/09/2017 21:41:26: Is there any other machine with a very similar tail stock arangment ? as i said i have read in older threads that the ml 7 will fit, all is not lost as i can still use it for centering etc and in ref to drilling this is going to be my difficulty but as i only need to drill to re pivot my clock repairs i will aft to find a way to move the tailstock along, im begining to think the centre going through the tailstock something was wrong as the face plate does not fit either it is supposed to be m14x1.5 but on measuring the thread on the plate its 12mm
regards john . John, I think you have been finding some dodgy information, if you've read that an ML7 tailstock will fit a Cowells. I posted a link to "watchmaking.weebly" on your other thread ... With the greatest respect; I think you need to check exactly what lathe you have. Look at his pages about the 90 CW http://watchmaking.weebly.com/lathe-maintenance.html and also Cowells site. Rearding the faceplate: The early Cowells had a different headstock spindle to the recent ones, and of course the 'Watchmaker' version has another variant. MichaelG. . For info. : This is the early headstock spindle: Edited By Michael Gilligan on 10/09/2017 22:04:44 |
Frances IoM | 10/09/2017 22:10:42 |
1395 forum posts 30 photos | the earlier Perris lathes used a 0.5" UNF thread on head stock - maybe the face plate is from an early version - the 14mm 1mm thread spindle may be an upgrade as the new and old spindles should fit the old headstocks
Did Cowells switch to 14 x 1.0mm as I note that this thread is mentioned by ArcEuro in their chuck faceplates Edited By Frances IoM on 10/09/2017 22:17:51 |
Nick_G | 10/09/2017 22:15:00 |
![]() 1808 forum posts 744 photos | . Guy's it's the tailstock he has a problem with not the headstock.
Nicl |
Michael Gilligan | 10/09/2017 22:16:13 |
![]() 23121 forum posts 1360 photos | Frances, Yes, the early spindle is the one that I illustrated ... Cowells later changed from that to the de-facto [Unimat] size of 14x1 MichaelG. |
Michael Gilligan | 10/09/2017 22:17:14 |
![]() 23121 forum posts 1360 photos | Posted by Nick_G on 10/09/2017 22:15:00:
. Nick ... Read the bit about the faceplate "something was wrong as the face plate does not fit either it is supposed to be m14x1.5 but on measuring the thread on the plate its 12mm This ^^^ is why I suggested that John needs to check exactly what lathe he's got. MichaelG. Edited By Michael Gilligan on 10/09/2017 22:21:06 |
Frances IoM | 10/09/2017 22:21:01 |
1395 forum posts 30 photos | Nick he also has a non-fitting faceplate which looks as tho from a different model than the one he thinks he has. Suspect buying a thread gauge should be a first purchase! |
Nick_G | 10/09/2017 22:23:16 |
![]() 1808 forum posts 744 photos | . Ooops. My bad.
Nick |
JOHN BURNELL 1 | 10/09/2017 22:42:47 |
![]() 20 forum posts 9 photos | Yes the plate and the headstock thread are most defanatly different, i have ordered some 6mm LH thread stud of ebay going to have a go at making somthing to do the job, i will post some pictures of the lathe, the plate of the unimat would fit, anyway many thanks for your help, as a mater of interest is there any other tailstock that fits, this is just in case i find one,
regards john |
Cornish Jack | 10/09/2017 22:53:49 |
1228 forum posts 172 photos | The tailstock problem sounds very odd - in particular the 12mm dimension. That size was the spindle thread size for the Unimat SL version - most definitely not compatible! Cowell spares are, indeed, expensive, but their customer service was excellent in the couple of times I have contacted them. rgds Bill |
JOHN BURNELL 1 | 10/09/2017 23:06:52 |
![]() 20 forum posts 9 photos | I think i might not have explained properly, the faceplate thread is 12mm and the headstock thread is 14 ? so the plate is from a diferent lathe i think, my tailstock is mt0 but the lh screw that goes through the centre to move the chuck back and fourth has snapped so i have ordered some LH thread stud bar and am going to try and make something up.
regards john |
Frances IoM | 10/09/2017 23:06:55 |
1395 forum posts 30 photos | I presume the older Perris tailstock would fit - these are I think cheaper than new Cowells but suspect don't come up that often. There is a series of 3 articles in ME in 1988/9 - first article issue dated 16 Dec (page760 but I didn't note issue # on my copy) on making a capstan/turret for a Perris/Cowells lathe |
James Alford | 11/09/2017 07:39:25 |
501 forum posts 88 photos | The Flexispeed is a predecessor of the Cowells. On mine, because the taper is not too good, I have looked at using a Peatol / Taig tailstock centre and fabricating a lever arm to drive it, using the screw holes that secure the retaining collar for the original threaded drive as fixing points. The Peatol centre is 12.5mm OD and readily available from the UK supplier. It has a centre turned on the end and is threaded to take a chuck. You can see a picture of the entire tailstock on the accessories page at **LINK** This might be an alternative to trying to fabricate a threaded centre with a female taper if the bore of your tailstock casting will accommodate it. James
Edited By James Alford on 11/09/2017 07:40:28 |
