Hillclimber | 08/09/2017 12:23:04 |
![]() 215 forum posts 51 photos | I stumbled onto this picture of an S7 fitted with what appears to be a gravity-feed cutting fluid delivery system? That looks like a drip-oiler cup fixed to a partly-hollow post mounted on the cross-slide? Just wondering if any of you have experimented with similar? And might share pictures? Cheers, Colin |
John Haine | 08/09/2017 12:41:04 |
5563 forum posts 322 photos | Interesting idea, looks like it would soon run out. |
Brian Sweeting | 08/09/2017 16:54:22 |
453 forum posts 1 photos | Not a new idea but a good drip oiler. Â See Emmas' igram picture here .. Â |
Robbo | 08/09/2017 19:25:03 |
1504 forum posts 142 photos | Colin Int 'tholden days it was common to have a shelf behind and above the lathe. Put a gallon (4.5 litre) can with a flexible tube and nozzle on the end from can to lathe. Simple tap on nozzle (eg motorbike fuel tap) and let it drip away. A bucket under the swarf tray outlet collected the run-off coolant which was returned to the can. I'll try and find a picture. |
the artfull-codger | 08/09/2017 19:32:40 |
![]() 304 forum posts 28 photos | I've had a 1 gal plastic tank on a shelf above my lathe for years & the usual pipe down to the tool with a valve, it provides all the coolant you need, I collect the coolant in the tray outlet & filter it then back in the "header tank",I wouldn't bother with all the fancy (& sometimes expensive) ideas for a pumped system,I don't bother with the myford, just use a brush & oilcan but only on the student, which does 90% of my turning. |
the artfull-codger | 08/09/2017 19:34:25 |
![]() 304 forum posts 28 photos | Haha, you beat me to it Robbo whilst I was typing!! a man after my own heart!!
Roderick Jenkins | 08/09/2017 20:13:07 |
![]() 2376 forum posts 800 photos | From Tubal Cain's "Simple Workshop Devices": Cheers, Rod |
Hillclimber | 09/09/2017 08:49:26 |
![]() 215 forum posts 51 photos | Posted by the artfull-codger on 08/09/2017 19:32:40:
I wouldn't bother with all the fancy (& sometimes expensive) ideas for a pumped system,I don't bother with the myford, just use a brush & oilcan And indeed, I spent 80p at Ikea yesterday acquiring a handy plastic bottle that has a trigger spray pump with adjustable nozzle.... |
Juddy | 09/09/2017 10:38:30 |
![]() 131 forum posts | I use one of these small pumps in a builders bucket positioned under the lathe, powered by an old router plug in 12v adaptor. with a length hose to one of these, and a return hose to the bucket from the swarf tray. works really well and is capable of supplying more than enough coolant. I drop the pump into a fine mesh sleeve to protect it from metal particles, and dangle a magnet into the bucket now and then to collect any settled swarf. Has been working fine for the last year or so, - now I've said that it will probably pack up.
Hillclimber | 09/09/2017 11:08:52 |
![]() 215 forum posts 51 photos | *old sock* Posted by Juddy on 09/09/2017 10:38:30:
