Dovetails in wood
Small scale dovetail jigs
Speedy Builder506/09/2017 13:18:44
2878 forum posts
248 photos
Can anyone give me advice as to commercial jigs for making dovetails in wood as thin as 1/4". Most jigs seem to start at thicknesses in excess of 1/2".
BobH
JasonB06/09/2017 13:21:20
Look at the Leigh jigs, not cheap but they work well and go down quite thin, you can also have one part thin and the other thick. I like mine.
Edited By JasonB on 06/09/2017 13:22:09
Jon Gibbs06/09/2017 13:28:07
750 forum posts
For through dovetails, can you not cut two sides at once if they're that thin, or perhaps use a scrap backing piece to make up the thickness to the minimum?
Usually the problem is getting the capacity to handle thick enough timber.
Jon
V8Eng06/09/2017 14:06:19
1826 forum posts
Axminster Tools seems to be a good place for woodworking equipment and tools.
www.axminster.co.uk
I have to say that I actually know nothing personally about Woodwork (except how to ruin it).
Edited By V8Eng on 06/09/2017 14:08:31
Ian Parkin06/09/2017 14:28:35
1174 forum posts
303 photos
its been discontinued but I use the trend dc400 jig
You can find used examples on ebay from time to time its really good at all different thicknesses and allows you to space dovetails as you wish and through or lapped DT's
And box joints too
It can do thin 6mm or so up to 20mm
Speedy Builder506/09/2017 17:26:49
2878 forum posts
248 photos
Thanks for the info, but the DC400 and its supercedant will only cut on material 19mm and thicker - I need about 7mm upwards. Jewel box trays etc.
BobH
Ian Parkin06/09/2017 17:35:54
1174 forum posts
303 photos
I must chuck away all the boxes and projects i have made with my 3 dc400's as I've made them out of too thin wood then
Ian Parkin06/09/2017 18:24:13
1174 forum posts
303 photos
Plus there's not a supercedant to the dc400
JasonB06/09/2017 18:40:00
The Leigh ones will go down to 1/8" thick material and upto about 1.25" for through dovetails, see chart
Also take a look at the Gifkin Jigs, they will go down to 2mm but need a router tabel as you move the jig and work over the inverted tool, fixed spacing though.
Edited By JasonB on 06/09/2017 18:45:01
Simon Collier06/09/2017 21:17:44
525 forum posts
65 photos
I have the Gifkin jigs. Very quick and easy to use.
Cornish Jack06/09/2017 23:16:38
1228 forum posts
172 photos
I have an Arcoy jig to be disposed of but not sure (will check in the shed tomorrow) what sizes it covers.
rgds
Bill
harold07/09/2017 11:33:22
35 forum posts
Router Boss or WoodRat will both do narrow dovetails, pretty much indistinguishable* from hand-made.
Not cheap.
*cognoscenti excepted, obvs.
HTH
Edited By harold on 07/09/2017 11:33:45
