Cutting the end off a carbide endmill
David Colwill05/08/2017 10:35:26
782 forum posts
40 photos
Hello,
I have a selection of carbide endmills that I picked up for next to nothing because they have chips on the ends. I had thought that I may be able to lop the ends off with a 1mm abrasive cutoff disc but having tried it, it is not going to work.
I therefore need to find some other way, presumably involving diamonds. I tried an old tile cutting blade but that wasn't any good either.
Has anyone used anything particular or have any recommendations. I don't mind spending money on the right thing but would like some assurance of success before splashing out.
Ideally I would want something 100mm diameter but I could probably accommodate 115mm at a push.
Many thanks in advance.
David.
Neil Wyatt05/08/2017 10:50:46
19226 forum posts
749 photos
86 articles
Have a look here
www.arceurotrade.co.uk/Catalogue/Diamond-Tools/Diamond-Discs-Diamond-Burrs
David Colwill05/08/2017 10:54:47
782 forum posts
40 photos
Thanks for that. I hadn't seen those on Arcs website. For that price they have to be worth a punt.
David.
Angus Anderson 105/08/2017 11:03:23
10 forum posts
You could try a diamond grinding cup wheel off ebay:
http://www.ebay.co.uk/itm/Grit-180-Diamond-Aluminum-Resin-Bowl-Shape-Grinding-Wheel-150mm-OD-Cutting-/262887397955?epid=1573188159&hash=item3d354f5a43:g:T6cAAOSwCU1YwSo7
I bought one of these and mounted it on my bench grinder, I had to turn two clamping adaptors so it would fit and run true on the grinders shaft. Other diameter wheels are available. It is brilliant for touching up HSS and carbide tools. No signs of wear after 1.5 yrs use.
Angus
David Standing 105/08/2017 13:44:38
1297 forum posts
50 photos
Posted by Angus Anderson 1 on 05/08/2017 11:03:23:
Angus
Unless I have completely misread the first post, David doesn't want to sharpen the end mills, but cut them off.
Andrew Entwistle05/08/2017 13:56:41
120 forum posts
218 photos
Hi David,
I have used the type of diamond disc that Neil linked to, dry, at about 10000 rpm with a Dremel to gash a 5 mm carbide endmill that I had sharpened the same way Angus does. The disc made short work of the gashing and could easily have sliced right through the 5mm carbide cutter.
Andrew.
David Colwill05/08/2017 14:56:16
782 forum posts
40 photos
Thanks for the replies.
I've ordered a couple of the 100 mm discs from arc and will report back soon.
Many thanks.
David.
Vic05/08/2017 16:13:25
3453 forum posts
23 photos
What are you planning to do with them David?
John Reese05/08/2017 16:19:20
1071 forum posts
I use the diamond plated discs in a dremel tool. It only has one layer id diamond on the edge so life isn't great. I use them for cutting off the end mill. I have some 4 1/2 discs about 3/32 thick that are diamond plated. I use them for gashing the end of the cutter. Life of these seems to be ok. I have some masonry cutoff discs for my angle grinder that have been unused for many years. I thought I would try them for gashing and see how they work. I will reportbak on how they work.
Niels Abildgaard05/08/2017 17:32:47
470 forum posts
177 photos
I grind a v-shape notch .5mm deep all way round,clamp in vice and use a hammer.
Carbide is brittle like glas or diamond.
Edited By Niels Abildgaard on 05/08/2017 17:33:46
David Colwill06/08/2017 09:23:10
782 forum posts
40 photos
Once I have cut the end off I can resharpen them
David.
David Colwill08/08/2017 09:18:07
782 forum posts
40 photos
A quick update on this.
The discs arrived this morning and I used one to lop 10 mm of a 20 mm carbide endmill. I'm not sure how long they will last doing this kind of duty but at that price,,,,,
Many thanks for the input especially Neil for the link to Arc.
David.
