alternatives to brass plates
Colin Whittaker02/08/2017 15:34:04
155 forum posts
18 photos
If I was to build a clock using ball bearings instead of the usual burnished steel arbor in broached brass hole technology then would I still use brass plates for the frame?
Would steel or aluminium work just as well? Would it all come down to what looks pretty?
(This is not a question about the material to use for clock wheels.)
Thanks, Colin
Russell Eberhardt02/08/2017 20:51:50
2785 forum posts
87 photos
There's no problem using steel or aluminium other than cosmetics. Steel will need some rust proofing unless it's stainless. Aluminium needs to be a hard alloy so as not to distort and could be finished with graining like this:
If using ball bearings make sure you use stainless steel bearings and wash out all the grease with white spirit before use.
Russell;
roy entwistle02/08/2017 21:24:37
1716 forum posts
I have seen stainless with brass inserts for the holes, as a skeleton clock it looked ok
Roy
Bob Stevenson02/08/2017 21:27:56
579 forum posts
7 photos
Interesting,...why s/s bearings?
Ian S C03/08/2017 03:35:47
7468 forum posts
230 photos
NO oil, think rust, this is also a good idea for low friction bearings for Stirling, and other low powered motors.
Ian S C
Russell Eberhardt03/08/2017 07:32:18
2785 forum posts
87 photos
That's right Ian. They need to be run dry to avoid drag from any oil.
Russell
