Rik Shaw | 31/07/2017 13:00:28 |
![]() 1494 forum posts 403 photos | I have a QCTP which I would like to fit to my WARCO BH600G. Because the QCTP was machined to fit another type of lathe I want to replace the large threaded circular nut with a full width “T” nut. The circular nut is a loose fit in the slot but will not slide out as the detent plunger assembly seems to be sitting loosely in a hole in it keeping the nut roughly centred in the slot. How do I remove the detent plunger? As you can see from the under side there is no access to it. I have tried unscrewing the detent but it just rotates without unscrewing. I also tried a little levering with a small screwdriver with no luck. I need a cunning plan – anyone got one? Rik
Edited By Rik Shaw on 31/07/2017 13:02:03 |
ChrisH | 31/07/2017 14:05:56 |
1023 forum posts 30 photos | Just a thought, but what about 'gluing' a small rod to the detent say with a drop of Araldite or plastic metal or JB weld or similar and try lifting the detent out the way when the Araldite or whatever sets? If I remember rightly the Araldite can be later removed with heat. Have you asked Warco how it comes apart - they are usually quite helpful if you get to speak to the right person? Perhaps I would do that first!! Chris |
Neil Wyatt | 31/07/2017 14:24:33 |
![]() 19226 forum posts 749 photos 86 articles | junior hacksaw blade? Drill up from under the detent? |
John Haine | 31/07/2017 14:39:16 |
5563 forum posts 322 photos | Small strong magnet. |
I.M. OUTAHERE | 31/07/2017 14:46:26 |
1468 forum posts 3 photos | The ones on my lathe came out by turning upside down and giving it a couple of wraps with a plastic hammer , there may be a small burr stopping it coming out ? Another option is to leave it there bit glue it down in the hole with loctite or the like . |
Rik Shaw | 31/07/2017 15:44:11 |
![]() 1494 forum posts 403 photos | Its out. Used a chippies mallet, hand held the assembly and whacked the TOP a half dozen times and out it popped. It was being held in the hole with oily foundry sand. Thanks for all comments. Rik Edited By Rik Shaw on 31/07/2017 15:46:58 |
Brian Oldford | 01/08/2017 08:37:38 |
![]() 686 forum posts 18 photos | Posted by Rik Shaw on 31/07/2017 15:44:11:
Its out. Used a chippies mallet, hand held the assembly and whacked the TOP a half dozen times and out it popped. It was being held in the hole with oily foundry sand. Thanks for all comments. Rik Edited By Rik Shaw on 31/07/2017 15:46:58 I thought poorly cleaned far eastern casting were a thing of the past. |
Rick Kirkland 1 | 01/08/2017 09:31:29 |
![]() 175 forum posts | No, speaking from experience they are in fact a bang up to date feature. |
