Nige | 18/07/2017 20:48:42 |
![]() 370 forum posts 65 photos | My ML4 currently has a leather and steel link type belt on it but as i want to move the layshaft back a bit I will need a new belt. The first photo below shows the layshaft pulleys. They are about 1/2 inch wide at the outside edge and about 1/4 inch at the bottom. The photo below is of the driven pulleys on the mandrel. They are very similar to the layshaft pulley with the dimensions being only very slightly smaller than those on the layshaft. I would like to know what section vee belt I need please. I think it is called A section ? If anybody has recommendations for a suitable adjustable linked type belt that would be useful thank you.
HughE | 18/07/2017 21:14:56 |
122 forum posts | Nige, Details for v belts can be found in Tubal Cain's ME Handbook section 13. The width at the top for A profile is given as 13.29mm. Hope that helps. Hugh |
Nige | 18/07/2017 21:17:01 |
![]() 370 forum posts 65 photos | Thanks Hugh. my measurement of 'about 1/2 inch' is probably quite close but I will check more closely tomorrow. |
John Haine | 18/07/2017 21:17:47 |
5563 forum posts 322 photos | Fenner Twist Link is good. I use it on my Super 7. You can get it from RS at a price but there may be other sources. Aha! Lathes.co.uk stock it: Actually I may have got mine from there. I use it both on my lathe and VM-B milling machine. |
Meunier | 18/07/2017 21:23:29 |
448 forum posts 8 photos | Re Fenner Twist Link or similar, has anybody had any success using it for replacing Tri-Leva belts on ML7 ?> Thanks |
Robbo | 18/07/2017 22:07:58 |
1504 forum posts 142 photos | Probably 'A' section. Have a look here - **LINK** |
Nige | 18/07/2017 22:17:29 |
![]() 370 forum posts 65 photos | John Haine: Thanks I will measure up and give Tony at lathes.co.uk a call tomorrow. Robbo: Thanks 😀 Edited By Nige on 18/07/2017 22:19:10 |
Nicholas Farr | 18/07/2017 22:31:12 |
![]() 3988 forum posts 1799 photos | Hi Nige, some guidance on measuring pulleys can be found in this **LINK** and belt sizes can be found by using the R/H arrow. Regards Nick. |
V8Eng | 18/07/2017 23:01:36 |
1826 forum posts 1 photos | Posted by Meunier on 18/07/2017 21:23:29:
I do not think they would work on a Tri-Leva assembly, if I remember rightly you need a smooth outer surface on the back of each belt for the tensioning rollers to press against. You could probably use a link belt on the drive from the motor to the idler (counter shaft?) pulley though. Edited By V8Eng on 18/07/2017 23:09:16 |
Meunier | 19/07/2017 19:57:11 |
448 forum posts 8 photos | V8Eng, double-drat, yes now you mention it - of course. Ah well, was hoping to avoid taking it all apart. Thanks |
