alan-lloyd | 17/07/2017 18:28:13 |
![]() 183 forum posts | I read somewhere you can blue mild steel using bees wax, does anyone know the method? |
Neil Wyatt | 17/07/2017 19:26:41 |
![]() 19226 forum posts 749 photos 86 articles | The challenge is heating the object evenly, a bed of sand above a heat source is one way. Once the colour develops any oil or wax will help keep it. I did this by heating with a cook's blowtorch!
Harry Wilkes | 17/07/2017 21:09:07 |
![]() 1613 forum posts 72 photos | Nice colour Neil H |
John McNamara | 18/07/2017 15:36:23 |
![]() 1377 forum posts 133 photos | By far the best book on Colouring metal I have found is the Modern Gunsmith By James Virgil Howe 2 vols 1941 Regards |
Kiwi Bloke | 28/07/2017 02:30:40 |
912 forum posts 3 photos | I've had a quick look through 'Firearm Blueing and Browning', by R H Angier, dating from the 1930s, but still available as a reprint, from Stackpole Books (USA). This is the 'bible'. However, it shares that book's disadvantage of not having an index, so searching is a pain, and I might have missed something. I have found reference to wax being used only as an after-treatment, to provide corrosion protection. Like shoe polish, and the Karate Kid, 'wax on', then 'wax off'... The book's a bit of a nightmare, because there are so many ways to produce the magnetite oxide on steel, varying from tedious hard work via alchemy to simple stuff. There's little guidance on their relative merits and the chemical nomenclature is obsolete in many places. Cooking up in a boiling solution of 80oz sodium hydroxide and 50oz potassium nitrate in 1 gallon of water (sorry about the units) is easy and effective - and rather nasty... The desired boiling point is 140 C, and is adjusted by the amount of water. Since the water tends to boil off, you may wish to add more at some time. Beware! The colour develops rapidly. Rinse well, dry and oil. Like electroplating, surface preparation is everything, and thorough degreasing is vital. Solvent degreasing tends to leave residue: hot alkaline detergents are the way to go - and keep your hands out of the stuff! |
I.M. OUTAHERE | 28/07/2017 06:57:23 |
1468 forum posts 3 photos | Need to distinguish between chemical bluieing and heat / oil blueing , if you want to heat blue then check out the clickspring youtube channel his results are stunning . I was tought to use old engine oil or transmissions fluid for heat / oil blueing . Chemical blueing as used on guns is is to be avoided unless you like toxic chemicals and i used to go to the local saw blade manufacturer to get my guns blued - did a top job too !
Ian |
Jon Gibbs | 28/07/2017 08:18:52 |
750 forum posts | I bought some Birchwood Casey Super Blue and it's very easy and quick on mild steel. Can't say I "like toxic chemicals" as per Ian's comments above but sometimes they make sense. HTH Jon |
John McNamara | 28/07/2017 09:08:59 |
![]() 1377 forum posts 133 photos | Some cold bluing solutions contain Selenous acid, **LINK** As an aside I walked into an antique shop a few years back and there on some shelves was a collection of old chemist jars and bottles still full of various chemicals. One large jar was marked corrosive sublimate it was 3/4 full there must have been a KG of the stuff. I asked the owner if he knew what it was. He did not! Corrosive Sublimate is an old name for Mercuric Chloride. Surprisingly he was not concerned that that jar contained a seriously dangerous poison. Who knows what the other jars contained He liked the different colours! Regards Edited By John McNamara on 28/07/2017 09:09:55 |
I.M. OUTAHERE | 28/07/2017 09:48:33 |
1468 forum posts 3 photos | Posted by Jon Gibbs on 28/07/2017 08:18:52:
I bought some Birchwood Casey Super Blue and it's very easy and quick on mild steel. Can't say I "like toxic chemicals" as per Ian's comments above but sometimes they make sense. HTH Jon Got some of the same stuff and i was going to do the nuts on my score engine and not too toxic , i was talking about the blueing gunsmiths use and it uses cyanide baths to cause the rusting of the metal. If you want chemical blueing you can try your local saw blade manufacturers as they do it all day every day .
John McNamara | 28/07/2017 10:17:49 |
![]() 1377 forum posts 133 photos | Yep Birchwood uses Selenous acid See the safety sheet. **LINK** My Father used to make cold blue in the 60's so a while back. Regards
I.M. OUTAHERE | 28/07/2017 10:35:33 |
1468 forum posts 3 photos | There is a down side to just about anything John but it is always helpful to have people with your experience here to guide the less experienced through these processes . I had a gunsmith that did a lot of work on my rifles and he did his own blueing , he admitted that it,was slowly killing him . Ian.
Windy | 29/07/2017 15:58:40 |
![]() 910 forum posts 197 photos | Posted by John McNamara on 18/07/2017 15:36:23:
By far the best book on Colouring metal I have found is the Modern Gunsmith By James Virgil Howe 2 vols 1941 Regards I have just recievedt the DVD PDF for £6.99 from Ebay a very interesting read also 50 free e books on old guns with it. |
Jon | 30/07/2017 21:57:51 |
1001 forum posts 49 photos | Awesome job there Neil, key is getting the heat even throughout the whole block. Had many a burn from hot blacking, it spits spewing out 145 degrees minimum to 160 degrees. Then theres the burn the oil on to give the part a colour. Books most were written decades ago and ingredients unavailable or substituted for others, most don't work in that respect.
