sean logie | 09/07/2017 18:56:42 |
![]() 608 forum posts 7 photos | Been trying to find spindle bearings for the Centec2 mill and not having much joy . Sizes are as follows ...
Rear bearing ... Od...2.240" ,56.92mm I'd... .749" 19.03mm W... .63" 15.9mm Front bearing Od... 2.240" 56,92mm id... 1.125". 28.58mm W... .630 15.9mm
I'm assuming they're Imperial .
Sean
John Reese | 09/07/2017 19:00:42 |
![]() 1071 forum posts | Aren't there numbers stamped into the cups & cones? |
JasonB | 09/07/2017 19:19:35 |
![]() 25215 forum posts 3105 photos 1 articles | Is that the overall width of width or one cup? if just the outer cup at 0.625" then the rear looks to be 1775-1729 Front 1988-1930 though there are a few other option sdepending on overal width see here Just search those numbers and you get something like this
Edited By JasonB on 09/07/2017 19:38:14 |
sean logie | 09/07/2017 20:10:04 |
![]() 608 forum posts 7 photos | Here's what's on the bearings .... Outer 1930 2-0 Inner 1985 1-6 Outer 1729 1-6 Inner 1775 4-6 Sean |
JasonB | 09/07/2017 20:24:46 |
![]() 25215 forum posts 3105 photos 1 articles | Slightly different spec on one of them to what I gave, follow the second link to buy them or just put the codes as I wrote them into google. |
Bob Rodgerson | 09/07/2017 21:28:37 |
612 forum posts 174 photos | If they are Imperial/old bearings try the Vintage Bearing Company. He deals mainly with cars & Motor Cycles but might well be able to help. |
sean logie | 10/07/2017 13:31:56 |
![]() 608 forum posts 7 photos | Phoned them this morning Bob and they have them in stock 👌 |
