gerry madden | 09/06/2017 15:45:36 |
331 forum posts 156 photos | Hi, I have some aluminium crank cases from a small engine that have been in a damp environment for a few years and have developed that patchy white dusty coating. I'm sure it will rub off with a bit of effort but I'm just wondering if there is a much more efficient way of cleaning these things up without leaving abrasive scratching marks in all different directions ? Gerry |
Jeff Dayman | 09/06/2017 16:00:05 |
2356 forum posts 47 photos | You might try a motorcycle engine repair shop for glass bead blasting. It will leave a nice clean matte finish on your aluminum and not mar any details or leave scratches. A coat of good clear car wax afterward, or some clear urethane spray clearcoat on outer surfaces, will keep the parts looking nice. JD |
Michael Gilligan | 09/06/2017 16:03:10 |
![]() 23121 forum posts 1360 photos | Gerry, The best way that I have found is to use a GaryFlex block [which is rather like the old school 'ink rubbers'], with Solvol Autosol polish as 'lubricant'. Yes, it's abrasive ... but very mildly so. MichaelG. |
Involute Curve | 09/06/2017 17:33:22 |
![]() 337 forum posts 107 photos | I vapour blast all my crankcases as a matter of course, the finsih is as new, but you must make sure you clean all oilways etc afterwoods. Shaun |
Neil Wyatt | 09/06/2017 20:14:13 |
![]() 19226 forum posts 749 photos 86 articles | I used my ultrasonic cleaning tank with a 'sensitive metals corrosion remover'. Not obvious from these shots, but it removed white 'bloom' as well.
Ian Skeldon 2 | 09/06/2017 23:36:17 |
543 forum posts 54 photos | DO NOT USE OVEN CLEANER, and don't ask me how I know |
ronan walsh | 10/06/2017 00:37:19 |
546 forum posts 32 photos | I boiled up some old cases in water with normal washing powder in it, the cases came out like new. But i tried it with a separate set of case sometime later, and they came out a blackish grey colour, not nice at all. Someone said it was because of the silicon content of the aluminium reacting with the contents of the powder. |
thaiguzzi | 10/06/2017 06:26:58 |
![]() 704 forum posts 131 photos | Posted by Involute Curve on 09/06/2017 17:33:22:
I vapour blast all my crankcases as a matter of course, the finsih is as new, but you must make sure you clean all oilways etc afterwoods. Shaun +1. Wot he said. There is no better finish. |
Tim Stevens | 10/06/2017 11:37:22 |
![]() 1779 forum posts 1 photos | Ronan is correct - some Aluminium alloys contain a high proportion of silicon, and when the Al is eaten away (by eg washing soda, or worse, caustic soda) the Si is left as dirty smudges. This is a major reason why anodising does not give good results on such alloys. Aluminium does not rust Cheers, Tim |
gerry madden | 10/06/2017 23:10:48 |
331 forum posts 156 photos | Well as usual some great info there. I didn't know about vapour blasting did some research and I'm impressed ! What's more there's a small business not far away from me that does it so I'll be visiting them next week. And by the looks of it, there's quite a few more bits and pieces they can do besides my crank cases. Thanks all for your input.
Gerry |
