Knurling wheels help
Michael Garbutt 108/06/2017 19:57:14
51 forum posts
Hi all im half way through building the Hemingway knurling tool but i need some wheels as the ones i have are to wide. any recommendations ? i think they need to be around 1/4 wide and a medium diamond .
Spurry08/06/2017 20:08:36
227 forum posts
72 photos
The ones supplied by Hemingway fit their kits, but they are not cheap, although they are the right size.
Michael Garbutt 108/06/2017 20:12:11
51 forum posts
i cant find any medium on there though. only seem to be fine or straight
Spurry08/06/2017 20:42:17
227 forum posts
72 photos
Must admit it was 2011 when I got medium from them. Wheels are 5/8" x 1/4". Might be worth a call though.
Michael Garbutt 108/06/2017 20:48:02
51 forum posts
may have to call
S.D.L.08/06/2017 22:20:28
236 forum posts
37 photos
Posted by Michael Garbutt 1 on 08/06/2017 19:57:14:
Have a look at MSC
`Steve
MW09/06/2017 09:42:55
2052 forum posts
56 photos
I do have to say this shows there are still some advantages to making your own knurling tool, even when cheap ones can now be obtained that do a reasonable job.
At least with a homemade one you can make it fit whatever stock bore sizes happen to be available to your area.
In other words, you're not necessarily stuck with a design that can't be altered easily.
Michael W
Roderick Jenkins09/06/2017 11:01:08
2376 forum posts
800 photos
I've bought 1/4" bore knurling wheels from various sources and they all seem to be slightly different widths. I'd make my tool capable of taking spacer washers to take up the difference for the narrower wheels.
Rod
HasBean09/06/2017 16:54:11
141 forum posts
32 photos
I seem to remember that I bought some from MSC of the right size (some tme ago though)
Paul
mark costello 110/06/2017 19:36:37
800 forum posts
16 photos
Some one with a surface grinder might be willing to whittle a set down.
john barnes 410/06/2017 20:28:49
32 forum posts
Gloster tooling sell what your looking for. I have fitted HSS medium diamond knurls 3/4" x 1/4" wide x 1/4" bore to a knurling tool I have just made and they work fine. Cost was £12.60 delivered.
Spurry08/11/2017 16:20:14
227 forum posts
72 photos
Apologies for resurrecting an old thread, but the info supplied (by me) above is incorrect.blush
The correct Hemingway wheels are 5/8" x 3/16" x 1/4" bore. It does seem a bit of an odd-ball size and they are not stocked in many places. Cromwell Tools do keep them but are rather expensive, but Hemingway does not keep much choice. Cromwell have them in Fine, Medium and Coarse versions.
Pete
thaiguzzi11/11/2017 13:27:21
704 forum posts
131 photos
phone photos to sept 2017 542.jpgIndeed. Hence I went with 1/4" width wheels. The arms are only 1/2" thick so you only have an 1/8" of steel either side in support, bit I've had no problems yet and it's been worked hard.
And because i'm a Cheap Charlie and had a surplus of 3/8" wide, brand name 1/4" bore wheels of different patterns, i made a jig and skimmed them down in my Stent T&CG - now that was fun. Not.phone photos to sept 2017 545.jpg
Edited By thaiguzzi on 11/11/2017 13:28:16
