Good for gears?
PETER ROACH | 26/04/2017 11:56:09 |
50 forum posts 25 photos | I am in process of making screw cutting clutch, S7, Graham Meek, design. I have run out of Tufnol, but seen pictures of the first two gears in the train made in Oilon. This is a considerably cheaper material and already in bar form. Will this work as a working material for this? |
Phil P | 26/04/2017 13:11:46 |
851 forum posts 206 photos | I made mine from Tufnol running on sealed ball races, but I would think Oilon (Oil Filled Nylon) would be a good modern alternative and certainly worth giving it a go. Phil |
Martin Connelly | 26/04/2017 13:54:24 |
![]() 2549 forum posts 235 photos | Nylacast have pictures of oilon components on their website that include gears so they think it is good for this purpose. If you have trouble getting small quantities at a low price I may have some scrap stock. Martin C |
Brian Wood | 26/04/2017 16:24:41 |
2742 forum posts 39 photos | Peter,
Brian Wood | 26/04/2017 17:10:32 |
2742 forum posts 39 photos | Sorry Peter, the gear that did the rolling over damage was the outer 30 T clutch gear, made in bronze; not the one I said earlier. The operational effects were of course the same. |
JasonB | 26/04/2017 18:28:30 |
![]() 25215 forum posts 3105 photos 1 articles | PM "KWIL" on here if you have any questions, it is his clutch in the photos and he used oilon and it works very well. |
KWIL | 26/04/2017 19:32:20 |
3681 forum posts 70 photos | Direct Plastics sell green oilon rod , not that expensive. |
PETER ROACH | 27/04/2017 10:10:01 |
50 forum posts 25 photos | Thanks for all the input. Nylacast link useful for the mechanical data. I have an old trade article on design of polymer gears so will pop the numbers in. Similar tensile but Oilon about half the impact and compressive strength of Tufnol. But other than noise assume that still useful to have a mechanical "fuse" in the system and not a problem if I make some spares. Direct Plastics was were I was looking 45mm dia x 500 @£12.55 going to yield about 22 slices, where as 200x300 x 20 Tufnol @ £43 I have got a small scrap of Tufnol which squeezed one blank of each 30T and 25T will but will a couple of teeth the tips will be missing, but even if I just use the Oilon to prove the rack cutter, which my preferred gear cutting method. Thanks |
