Want to stick pvc
tiler Jones21/04/2017 16:22:39
5 forum posts
Hi
I have a pvc waste pipe which I have threaded and I want to screw a what looks like injection moulded valve into it.
I want to seal the joint so it can not be removed but the pvc cement adhesive used for welding pipes does not work with the valve plastic.
Anyone advise me as to what I can use please.
Thank you
David Jupp21/04/2017 16:36:46
978 forum posts
26 photos
Seems likely that the valve could be PP, or PE - in which case getting any glue to stick will be a challenge. There are 'pre-treatments' available from some of the adhesive companies that claim to work with Polyolefins, though bond strength may still not be fantastic.
If you are feeling brave, you might 'flame treat' the surface of the valve - just a brief waft through a blue gas flame (not enough to melt/burn it). That should help adhesives to stick. Additives in the plastic can bleed out over time and reduce the effectiveness of such 'treatment', so best to do it immediately before gluing.
Ady121/04/2017 16:42:40
6137 forum posts
893 photos
A glue gun?
Silicone?
tiler Jones21/04/2017 17:38:40
5 forum posts
Ok I will see how I get on, its a bit of a pain as you say.
Glue gun wont adhere, silicone may be an option but I need it stuck. CT 1 might be an option I was thinking but its a bit of a faf. Thought an epoxi might of done it thats why I asked.
The valve is screwing into a pvc stop end from the inside and I need the thread that is then on the outside to fix too. This is why I need it stuck or screwing onto the outside will loosen the thread into the end cap - if you get me
Thanks
Ed Duffner21/04/2017 18:23:46
863 forum posts
104 photos
For PVC electrical conduit we used to use a solvent based 'glue' to bond joints. Egaweld was one brand name and another was a no-name solvent made by Marshall Tuflex.
Ed.
Brian Oldford21/04/2017 18:57:15
686 forum posts
18 photos
You original post suggests the valve will be mechanically attached by a thread. If you only want to seal it can you not use PTFE tape?
tiler Jones21/04/2017 19:19:53
5 forum posts
Ye I think I have a version of Egaweld and it doesnt like the molded plastic its whats used to weld waste pipe, it melts both surfaces into each other. I wish it would work.
PTFE is fine but its not a sealer, its Teflon and is made to make easy the coupling of brass tapered joints.
I am making a cylinder, inside the cylinder is a valve threaded through one end, attached to the piece that protrudes through the end will go a fitting that feeds the valve. RH thread out through the end, outside fixing is RH thread. Tighten outside too much and it loosens the other (ptfe will aid this). This is my problem I need to make the valve into the end Safe.
All good fun
Thanks guys
Edited By tiler Jones on 21/04/2017 19:21:38
Neil Wyatt22/04/2017 19:28:19
19226 forum posts
749 photos
86 articles
Ha! I got caught out trying to attach what I thought was PVC to genuine PVC. It barely adheres and the glue wouldn't set.
I went and bought some proper PVC section to replace the strap box stuff.
It really depends on what plastic the valve is made out of.
You might be better adding a second layer of PVC to give enough meat to screw the valve into securely.
Simon Williams 322/04/2017 23:07:26
728 forum posts
90 photos
Couple of thoughts -
Don't go anywhere near it with silicon(e), it won't stick to hardly nuffink (it's a gap filler) and once you've contaminated it with those little Si molecules nothing but nothing will stick to it., It's a common fallacy that it will seal a pressure joint, but it won't.
Some pipe fittings are injection moulded with ABS. At this time of night I'm struggling to remember if it's PVC glue that won't stick ABS, or the other way round, but I know one glue sticks (solvent welds) both and the other only sticks the one. But this assumes the valve is moulded from such. If you could put up a picture of the valve it might tell us what we're trying to deal with. If the ABS/PVC choice looks like the right line of logic I'll do the research.
Finally, anything Loctite related wrecks PVC or ABS, don't understand the chemistry but it won't seal no way no how, not never.
HTH Simon
