Martin Faulkner | 17/04/2017 19:46:04 |
85 forum posts 32 photos | Hello all, just been cleaning my big box of lathe bits. I have a Boxford lathe and came across this. Can anyone tell me what it is? |
Martin Faulkner | 17/04/2017 19:46:35 |
85 forum posts 32 photos | |
Curtis Rutter | 17/04/2017 19:47:23 |
133 forum posts 14 photos | Looks like a chuck backplate to me |
Stuart Bridger | 17/04/2017 19:51:31 |
566 forum posts 31 photos | Catch plate for between centres turning? |
Martin Faulkner | 17/04/2017 20:03:30 |
85 forum posts 32 photos | There are no threads in the middle so I ruled out a chuck plate unless there is some forms of bolt on method. All this is new to me. I was just working through the box of bits that came with it. I don't even know if it is for a lathe. Catch plate? Is that the large round plate with the pin on the outer edge? This is only around 60mm diameter. |
Martin Faulkner | 17/04/2017 20:44:49 |
85 forum posts 32 photos | If anyone can help. Think this should be in workshop and tooling Section? Tried to change it but can not find any options to do so. |
Martin Cargill | 17/04/2017 21:01:36 |
203 forum posts | Blade flange for a woodworking saw? What is the bore size? Edited By Martin Cargill on 17/04/2017 21:04:06 |
daveb | 17/04/2017 21:23:21 |
631 forum posts 14 photos | Man with a magnet stuck to his leg? |
Martin Faulkner | 17/04/2017 22:14:32 |
85 forum posts 32 photos | Not sure on the blade flange, it's got 2 holes and a nipple. Can not see how it would hold a blade. It not my leg, it's the 10,000 tons of steel stuck in the fabric of the pants. Lol |
Martin Cargill | 18/04/2017 08:03:39 |
203 forum posts | The reason I said blade flange is that some blades use drive pins to stop the blade from tightening and to stop them from spinning off during braking. I see a few of them that have a range of holes to work with different blade pin holes(it's easier to drill a flange than to drill a hole in a blade) |
Martin Faulkner | 18/04/2017 21:12:57 |
85 forum posts 32 photos | Posted by Martin Cargill on 18/04/2017 08:03:39:
The reason I said blade flange is that some blades use drive pins to stop the blade from tightening and to stop them from spinning off during braking. I see a few of them that have a range of holes to work with different blade pin holes(it's easier to drill a flange than to drill a hole in a blade) I do understand what your saying and have not ruled out your idea. The center hole diameter is 11/16 or 17.6mm. |
