Adding text to metal
Curtis Rutter06/04/2017 22:32:53
133 forum posts
14 photos
The next project I'm looking at making requires letters to be put onto rings. I was thinking of punching these but wondered if anyone had any better ideas as the rings that would need punching are going to be a bit on the thin side
Brian H06/04/2017 22:59:07
2312 forum posts
112 photos
Laser cut??
Nick Hulme06/04/2017 23:05:40
750 forum posts
37 photos
Depending on the material masking and chemical etching may be an option.
Maurice06/04/2017 23:10:58
469 forum posts
50 photos
I once wanted to put some lettering round a circle and did it on my lathe. Having turned the ring, in my case brass, I left it centred in the lathe and used letter punches guided by the slot in a quick change tool holder. The punches were held against the back of the slot by hand, and the clamp screws just brought down to lightly hold the punches down. The tool holder has to be squared to the work of course, and the punch payed on its side, adjusted to be at centre height. An indexing device was used to control the rotation between letters. A few experiments were needed to determine the amount to turn the work between letters. The gap varies depending on which letters are adjacent. A bonus was that I found it possible to give the punches an accurate second tap if needed. This was a one off job. If I was doing a lot, I think I would make some sort of sprung guides to hold the punches back and down in the tool holder slot. I the work is thin, then I think I would back it with some softish metal while punching, probably aluminium.
Maurice06/04/2017 23:12:12
469 forum posts
50 photos
That should read " payed on its side" , sorry.
Maurice06/04/2017 23:14:52
469 forum posts
50 photos
Both those postings will have to be "laying on its side". Spelling checker!!!
Double sorry.
David George 107/04/2017 07:58:52
2110 forum posts
565 photos
I had a plate engraved by local laser engraver verry quick and didn't cost a fortune no damage, any font and depth of cut.
David
roy entwistle07/04/2017 09:48:02
1716 forum posts
Have you got a local trophy engraver ? Or if in UK Timsons shoe repairers.  Try them
Roy
Edited By roy entwistle on 07/04/2017 09:50:18
