Curtis Rutter | 02/04/2017 12:20:46 |
133 forum posts 14 photos | What's this tool called? Is there any other tool suitable for use on the lathe to make large grooves off centre where you can't bore? |
mechman48 | 02/04/2017 12:46:30 |
![]() 2947 forum posts 468 photos | FWIW...Trepanning tool / form tool ... round nosed, for square bottomed grooves the end obviously will be square, make sure that the front edge has a radius on the bottom edge so it doesn't catch the outer radius of the groove if you're trepanning. |
pgk pgk | 02/04/2017 12:53:17 |
2661 forum posts 294 photos | You might also consider a round carbide insert.. so-called profiling tool. They go down to certainly 5mm diameter (perhaps smaller) but again the problem could be one of clearance. |
Nick Hulme | 02/04/2017 21:04:01 |
750 forum posts 37 photos | There are tools for face grooving but the tools and inserts are usually specific to a range of radii. Google "Face Grooving Tool" and click "Images" below the search bar. |
the artfull-codger | 02/04/2017 21:43:50 |
![]() 304 forum posts 28 photos | Looks like a home ground hss form tool for a particular job in brass as it appears to have no rake. |
