Bob Lamb | 01/04/2017 15:53:36 |
![]() 140 forum posts 51 photos | What's the best way to straighten small copper tube from a coil? At the moment I cut off a short length, anneal it and then roll it between 2 bits of MDF. It seems to work but I am sure there must be a better way to do it. Look forward to hearing better ideas. Bob
Dennis D | 01/04/2017 16:07:34 |
84 forum posts 3 photos | One method I read about and have tried was to cut off a length longer than needed. Clamp one end in the bench vice and clamp the other end in a pair of mole grips at right angles to the tube and then give them a whack with a hammer.I did this without annealing so the tube wasn't stretched |
Chris Evans 6 | 01/04/2017 16:36:55 |
![]() 2156 forum posts | What do you call small diameter tube ? When I operated a spark erosion machine we often used tube of 1mm or less to put small holes in. This was gripped in a collet chuck ready to fit on the spark machine, we would then put the collet chuck in the lathe three jaw and spin at 800 or more revs. When spinning lightly grip the tube with finger and thumb close to where being held and run your hand away from the chuck towards the tailstock. Sounds dangerous and scary but works and tube comes out straight after a couple of goes. |
Neil Wyatt | 01/04/2017 16:44:28 |
![]() 19226 forum posts 749 photos 86 articles | I would say that's probably the best way to do it Bob, it works well for me. |
Mike Poole | 01/04/2017 17:26:48 |
![]() 3676 forum posts 82 photos | Pyro MICC cable uses a roller box to straighten it after decoiling, thin sheet steel is straightened with a set of rollers after decoiling but the machine must be set up to run continuously or you will get roller marks that will be visible in the finished panels. Mike |
Bob Lamb | 01/04/2017 18:25:23 |
![]() 140 forum posts 51 photos | Thanks for those ideas. I wasn't thinking when I posted originally - by small I meant anything from ⅛" to ¼". I'm going to give the "Mole and hammer method a go but Chris sounds a braver man than me! ......... or am I just being a wimp? Bob
John Rudd | 01/04/2017 18:51:05 |
1479 forum posts 1 photos | Another vote for Mike's suggestion.... I've installed a lot of Pyro in my time, there is a proper tool for straightening Pyro... I've even visited the Pyro works when it was at Hebburn while serving my apprenticeship...(seems so long ago now..) |
vintagengineer | 01/04/2017 19:32:12 |
![]() 469 forum posts 6 photos | We used to cut off a 10 foot length, attach one end to a beam and put a large weight on the other end. Leave overnight and in the morning it would be dead straight. |
Harry Wilkes | 01/04/2017 21:44:00 |
![]() 1613 forum posts 72 photos | Posted by John Rudd on 01/04/2017 18:51:05:
Another vote for Mike's suggestion.... I've installed a lot of Pyro in my time, there is a proper tool for straightening Pyro... I've even visited the Pyro works when it was at Hebburn while serving my apprenticeship...(seems so long ago now..) Good visit the BICC wonder how many apprentices did it, back to straitening depending on the length I roll mine between two flat pieces of wood. H |
Neil Wyatt | 02/04/2017 09:42:36 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Bob Lamb on 01/04/2017 18:25:23:
I think a 1mm pipe might do less damage than a 1/4" one... |
Chris Evans 6 | 02/04/2017 10:07:45 |
![]() 2156 forum posts | My method for straightening small tube was brought about by necessity. You just can not use a DTI on tube sub 1mm diameter. Once on the spark machine the final check to see if it was straight was done using the machines audio facility, IE electrical contact and zero the read out then bring the quill down and check again. |
