Collets
What Collets
David Watson 324/03/2017 21:02:17
51 forum posts
Along with the Mini Lathe I inherited from my late father are some odd lathe parts not related to the Mini Lathe.
There is a Myford threaded nose cone and a set of collets that mach the nose cone, probly from his ML7. They are MT2 taper. How can I identify wihat collets they are. They look like ER collets but I am not sure what size they are?. The other problem may be that the Mini Lathe headstock is MT3.
I would like to use collets on the Mini Lathe having seen my Father using collets on his Rivet 608 for his clock making.
Phil P24/03/2017 21:22:09
851 forum posts
206 photos
Do you have a photo of the collets in question to help with identity ?
Phil
Robbo24/03/2017 21:40:29
1504 forum posts
142 photos
David
They sound like Myford collets and with the threaded "nose cone" - called a "nose piece" or collet closer - will only fit Myford machines as the spindle nose thread has to match the Myford thread inside the collet closer.
Myford collets are 2¼" long and 0.58" dia at the thin end. For ease of reference one is shown here
And the instructions for using them here
O f course I may be wrong!   E&O always excepted
Edited By Robbo on 24/03/2017 21:56:40
Michael Gilligan24/03/2017 22:14:46
23121 forum posts
1360 photos
David,
I was thinking along the same lines as Robbo ... but there is one important caveat
Any resemblance to ER Collets is quite superficial: Yes, both have a groove for the closing ring BUT the Myford ones are fixed size, and do not have the range of an ER.
David Watson 325/03/2017 08:37:20
51 forum posts
Thanks folks. The photos from Robo prove my thoughts that they are Myford only collets. I think starting again with ER 32 and a collet holder for the Mini Lathe is my best choice. My next thoiught being do I go for metric or imperial?.
I was offered an ML10 recently and if it wasnt thirty plus years old and a lot of money I would have found a use for the collets. Sadly my father gave his ML7 away when I was stationed abroad later followed by his Rivet 608 to be replaced by the mini lathe. Sad times but I am getting some use out of the mini lathe.
Michael Gilligan25/03/2017 08:49:39
23121 forum posts
1360 photos
David,
I have sent you a message
Robbo25/03/2017 08:59:09
1504 forum posts
142 photos
David,
The good news is that genuine Myford collets command a premium price on ebay and elsewhere, so you can get some money back to pay for your ER collets.
These days, unless you have a stock of Imperial cutters, I would go for Metric. My own ER collets are metric, while my old Clarkson and Myford ones are Imperial (as befits an old fogey).
Edited By Robbo on 25/03/2017 09:00:29
Brian Oldford25/03/2017 09:56:04
686 forum posts
18 photos
Whatever range of collets you have (imperial in 1/32"s or metric in millimeters) you should be able to grip anything within the range of the collet set you have.
Michael Gilligan25/03/2017 12:26:02
23121 forum posts
1360 photos
Posted by Brian Oldford on 25/03/2017 09:56:04:
Brian,
If you are referring to the Myford collets, then i beg to differ.
... each collet is designed for a specific size +/- a few thou' at most.
ER collets however, are, of course, 'extended range'.
Thor 🇳🇴25/03/2017 17:44:17
1766 forum posts
46 photos
Hi David,
I think getting an ER 32collet system is a good idea. You ask: "My next thoiught being do I go for metric or imperial?." That depends on the shank diameter of the end mills (or work) you use. I have mostly metric collets with a couple of imperial ones - 1/8" and 1/4" because I occasionally use 1/16" slot drills which have a 1/4" shank.
Thor
Brian Oldford26/03/2017 14:58:53
686 forum posts
18 photos
Posted by Michael Gilligan on 25/03/2017 12:26:02:
Brian,
You are, of course, quite correct. I failed to mention I was, in fact, referring to the sets of collets I have which are of the ER11 and ER25 series. My apologies for the ambiguity.
Michael Gilligan26/03/2017 18:53:47
23121 forum posts
1360 photos
Thanks for clarifying that, Brian yes
Phil P26/03/2017 19:08:41
851 forum posts
206 photos
Posted by David Watson 3 on 25/03/2017 08:37:20:
David
If you should be thinking of parting with your Myford collets, I am looking for 3/64", 13/64", 27/64 & 31/64" sizes.
These are not very common sizes, but if you do have any spare I would appreciate a message.
Thanks
Phil
Jon Gibbs26/03/2017 19:53:09
750 forum posts
I have a full set of metric ER32 collets for workholding but then a second smaller select mix of metric and imperial collets for end-mills since I have both metric and imperial.
I opted for 16mm, 1/2", 12mm, 10mm and 1/4" as the cheapest combination. It's fairly obvious but with this set none of the collets needs to be closed more than 0.5mm (10mm -> 3/8" worst case) to cover almost all of my end-mills.
HTH
Jon
peter blair27/03/2017 15:37:33
34 forum posts
25 photos
I don't mean to steal this thread but wonder if anyone can identify these collets I picked up for $5.00?
Hard to see in the photo but they are threaded on the outside of the end and do not have an internal thread.
Michael Gilligan27/03/2017 15:44:15
23121 forum posts
1360 photos
Peter,
Your slightly fuzzy photo appears to show them marked CD13
... So try here: **LINK**
http://www.miyakawa.com/en/products_e/multiple_head/collet_drill.htm
Nice find at that price !!
peter blair27/03/2017 18:44:58
34 forum posts
25 photos
Thanks Michael. I'm sure that's what they are. Now I don't know if I should buy the rest so I can use them or try to make a few $$$ by selling them. Once again, love this site!
