Lathe. Gearbox oil
Viceroy 280vs
Alan green 512/03/2017 17:20:36
3 forum posts
I have just acquired a Viceroy 280vs lathe, can someone kindly tell me what oil I need to use in the gearbox. Thanks Alan
Thor 🇳🇴12/03/2017 19:00:52
1766 forum posts
46 photos
Hi Alan,
Welcome to the forum. This manual says Shell Vitrea 68 (may be called Shell Morlina S2 B68 now).
Thor
clogs12/03/2017 19:06:50
630 forum posts
12 photos
Hi all,
I use Dextron, Automatic gearbox oil, it's non frothing......before anyone says to much about the quality of the Auto/g/oil.....also used in the average power steering system........
That Mercedes Sprinter that overtakes u on the Motorway at 100mph carring a 1 ton payload uses the same oil in it's manual gearbox's.......mine did over 200,000miles with no trouble.....
Clogs........
Alan green 512/03/2017 19:34:22
3 forum posts
Thank you both for the quick reply, I will only be using the lathe occasionally so I would think the shell will do the job, how much will I need ? thanks again.Alan
Vic12/03/2017 19:56:24
3453 forum posts
23 photos
I put Halfords gearbox oil in my Lathe.
Chris Evans 612/03/2017 20:09:51
2156 forum posts
Buy any "DIN" 68 spec oil and use it in the head and slideways. Lots of lathes use "DIN" 32 oil in the headstock.
Alan green 512/03/2017 22:36:42
3 forum posts
Thanks again for all your responses ,you've given me some good and varied advice,I'll let you know .Alan
Nigel McBurney 113/03/2017 09:09:19
1101 forum posts
Hi Alan I suggest you take a look at the popular and well informed "Lathes" website under the Viceroy VS lathes there is a warning marked up in red about using the correct oil,
Graham Wharton13/03/2017 10:17:02
149 forum posts
48 photos
Beware of using any old gearbox oil containing EP additives. Many of them are known to attack and corrode yellow metals such as bronze, brass and copper which are commonly found in lathe gearboxes.
Shell Vitrea, and its replacement Shell Morlina is a plain mineral oil specifically formulated for applications that DO NOT require EP additives and is therefore safe for use on yellow metals.
Graham
Jon Gibbs13/03/2017 11:12:02
750 forum posts
Hi Alan,
For ISO 68 Slideway oil I think you can do a lot worse than this at £20 for 5 litres delivered... MMAAOxyOalTa13W">http://www.ebay.co.uk/itm/SLIDEWAY-OIL-68-5-LTR-FOR-CNCs-LATHES-MILLING-MACHINES-ETC-QUALITY-BY-LUBETECH-/351082248507?hash=item51be21f93b:gMMAAOxyOalTa13W
from ebay seller lubetechoil.
No affiliation just satisfied customer.
Jon
