While many users are more than happy with the standard bearings fitted to Myford Super 7 lathes, some critics consider that roller bearings should have been fitted.
Neil Wyatt | 23/02/2017 12:43:54 |
![]() 19226 forum posts 749 photos 86 articles | In response to a query from a forum member, here's a reprint of an interesting and useful 2011 article by Ken Willson. Neil |
mgnbuk | 23/02/2017 12:59:18 |
1394 forum posts 103 photos | Logged in, MEW subscriber & can't access this Neil ? Nigel B |
Michael Gilligan | 23/02/2017 13:31:06 |
![]() 23121 forum posts 1360 photos | Posted by Nigel B on 23/02/2017 12:59:18: Logged in, MEW subscriber & can't access this Neil ? Nigel B . Working fine [for me] now, Nigel ... maybe Neil posted the note, before the link was activated. MichaelG. |
mgnbuk | 23/02/2017 13:36:58 |
1394 forum posts 103 photos | Sorry, this is Subscriber-only content... No difference when I just tried again, Michael Nigel B |
Neil Wyatt | 23/02/2017 13:47:16 |
![]() 19226 forum posts 749 photos 86 articles | Nigel, I've sent you a PM. I hadn't meant it to be subscribers only. I want those without subscriptions to see what they are missing Neil
Brian Wood | 23/02/2017 14:03:56 |
2742 forum posts 39 photos | For those who might be considering the modification, I made the change to my ML7B as a direct result of this article and have no hesitation in recommending it to others. |
KWIL | 23/02/2017 14:27:39 |
3681 forum posts 70 photos | Brian, Thank you |
Dick Ganderton 1 | 18/03/2017 13:23:06 |
8 forum posts | Definitely well worth doing. However, there are a few problems with the drawings and part numbers in the article. I have since found that the useless oil nipple on the rear bearing housing wasn't letting any oil through. I have replaced this with a brass oil cup that really does let the oil get through to the bearings. Here is what I found. (I think it was later published in MEW.)
I have just completed the mods to my Myford S7 Headstock as described in Ken Wilson's Article in the April 2011 Model Engineers Workshop. I have never been able to get this machine to run on the top speed range or to get the rear bearings to properly adjust to take end thrust when drilling with large drills. This is in complete contrast to my previous, earlier S7, which spent most of its life running at top speed with no trouble. Now I can run at top speed - I have even tried it at twice top speed as I have a 3-phase motor fitted driven from an invertor to give speed control. However, I think that there are problems with the dimensions given for the modifications to the two locking rings and the new spacer. The recess depth, given as 3.4 - 3.5 mm (0.134" - 0.138" in understandable units) is not deep enough to clear the inner race of the new bearings. I had to increase the depth to 0.140" to just clear the inner race - 0.144" would be better. It's very frustrating to discover this when you have got the headstock in bits and no way to remachine the rings! Fortunately, I had opted to buy new rings from Myford - the part number is G2340 not G2430 as quoted in the article, order that part number and you will get a driver plate - so I was able to put the headstock back together and take the extra few thousandths off. Having gone to the trouble to make a new spacer to the dimensions given in the article, I found that with it fitted the front locking ring protruded too far into the headstock while the rear one was so far into the housing that the C-spanner could not get hold of the slots. So I put the old spacer back and everything was OK. It's definitely worth doing the mods as it now runs faster and quieter and is much easier to adjust than with the standard ball races.
Dick G |
KWIL | 18/03/2017 16:08:41 |
3681 forum posts 70 photos | Dick, I am sorry you had the difficulties you describe. As stated in the article the bearing are metric and so I kept to those units (I too am an imperial person). Dyslexic fingers are the cause of the G number error in transcribing from the Myford parts listing. As you had only one lathe you could well have tried the bearing against the modified locking ring whilst still in the chuck so avoiding any interference troubles, a long term held view of this hobby, never trust drawings!! I am pleased, that in the end, you found it all worth while. Long may your lathe run well. Ken Willson |
