While many users are more than happy with the standard bearings fitted to Myford Super 7 lathes, some critics consider that roller bearings should have been fitted.
At the very least, those seeking to run their lathe regularly at higher speeds may wish to consider this roller bearing conversion described by Ken Willson.
You may down load the article HERE
This article originally appeared in the Model Engineers Workshop issue 175 April 2011.
Thread | Replies | Views | First Post | |
![]() | Roller Bearings for a Myford Super 7 By Neil Wyatt | 8 | 5298 | 23/02/2017 12:43:54 by Neil Wyatt |
