Slant gears?
vintagengineer16/02/2017 22:05:59
469 forum posts
6 photos
I am rebuilding a 1914 petrol engine that has twin cams. One of the timing gears is missing. I need to make a replacement, I have measured them and they appear to be cut at an angle of 14 1/2 degrees but are straight not helical.
I assume I can cut the gear the same as straight spur gear but at the correct angle.
Anyone has come across this type of gear before?
Hopper16/02/2017 22:11:51
7881 forum posts
397 photos
Yes, but I made it myself. Works well as a wormwheel on a dividing head, meshed with an Acme thread of suitable pitch. I made it just as you say, same as a straight spur gear but mount the blank at the suitable angle. No idea how it would go meshing with another gear rather than a worm.
John Stevenson16/02/2017 22:12:58
5068 forum posts
If they are cut AT AN ANGLE of 14 1/2 degrees then regardless they are helical
Phil P16/02/2017 22:19:35
851 forum posts
206 photos
Can you put us a close up photo of the gear in question please.
I doubt very much it will be an angled gear as you describe and think it probably is a helical gear, but I would be very interested to see it all the same.
If teeth were cut at an angle across a gear blank, they would be shallower at the sides and deeper in the middle, I don't think that would make for a very good gear if it has to mesh with another one the same.
The only time I have seen this type of gear in use, is as an alternative to a true worm gear on a cheap dividing head, but in that application it is only the centre of the teeth that have contact with a worm and you can sort of get away with it.
Phil
PS. Hopper and JS both type a lot faster than me !!
Edited By Phil P on 16/02/2017 22:21:18
vintagengineer16/02/2017 22:27:06
469 forum posts
6 photos
I will post some pictures tomorrow. They are cut in a straight angle ( I have clocked them to confirm this) rather than a helix and they alternate lefthand - righthand so that they mesh. But because of the angle they have thrust washers on all the gears.
John Stevenson16/02/2017 22:31:16
5068 forum posts
It's a bit like 20 questions isn't it ?
vintagengineer17/02/2017 19:59:14
469 forum posts
6 photos
John Stevenson17/02/2017 20:34:58
5068 forum posts
That is a helical gear.
I'd suggest that you get hold of a copy of Ivan Laws fine book Gears and Gearcutting, No 17 in the Workshop practice series and all will become clear.
vintagengineer17/02/2017 20:45:25
469 forum posts
6 photos
Will do, thank you.
Hacksaw17/02/2017 22:48:19
474 forum posts
202 photos
Now tell us what the engine is ! Alfa?  , Peugeot
Edited By Hacksaw on 17/02/2017 22:50:19
vintagengineer17/02/2017 22:56:45
469 forum posts
6 photos
White and Poppe / Dennis Brothers Motors. Customer cannot get an exact date but we think its a 1914 engine as it has some W+P parts and some Dennis parts. 5 litres, 4 cylinder T head.
Hacksaw17/02/2017 23:03:17
474 forum posts
202 photos
I've got a Dennis ..a 36" Blackburn 500cc beast !
John Reese19/02/2017 16:17:36
1071 forum posts
There was a post within the last year or two dealing with cutting helical gears. I searched but could not find it.
I responded to it stating that the traditional method was to use a universal mill (table swivels) and a universal dividing head geared to the lead screw. Several members responded with work-arounds devised by model engineers to cut helical gears without the specialized equipment. I searched for that post but was unable to find it. Perhaps another member can post a link. I think you would find it useful.
You might need to search for a commercial gear shop that could do it on a hobber.
Andrew Johnston19/02/2017 16:37:17
7061 forum posts
719 photos
Posted by John Reese on 19/02/2017 16:17:36:
Here:
And for reference the 'traditional' way:
And less conventionally on a vertical mill:
Neither of these methods produce the correct tooth form, although for many practical purposes the gears work well.
