Curtis Rutter | 11/02/2017 23:34:33 |
133 forum posts 14 photos | The plans I have require a 22mm glass tube for the displacement cylinder and 18mm for the piston. I can't find anything appropriate to buy. The obvious choice was a test tube but 22mm doesn't seem to be a standard size..... Any recommendations, I'm in the U.K. Edited By Curtis Rutter on 11/02/2017 23:36:10 |
RichardN | 12/02/2017 07:27:43 |
123 forum posts 11 photos | Would standard Borosilicate tube do? I've bought from this bunch before- send a message and they can create pretty much whatever you need with nicely ground ends I believe. |
Curtis Rutter | 12/02/2017 07:39:56 |
133 forum posts 14 photos | If they can do rounded ends that would be perfect, shall contact them. Borosilicate will be fine. |
Ian S C | 12/02/2017 08:55:21 |
![]() 7468 forum posts 230 photos | If you can't get the glass tube, its still possible to do the build by using stainless steel, you can make the cup shape by welding an end on a bit of tube, job for a TIG welder, or you can carve it out of solid bar, takes time, but well worth it. Both the hot cap and the displacer can be made the same way. One of my motors, built from junk found in the workshop. Power cylinder 3/8" bore x 12" stroke. The hot cap is made from the steel case from a dead AA size Nicad battery. Ian S C |
Curtis Rutter | 16/02/2017 11:43:09 |
133 forum posts 14 photos | Posted by RichardN on 12/02/2017 07:27:43:
Would standard Borosilicate tube do? I've bought from this bunch before- send a message and they can create pretty much whatever you need with nicely ground ends I believe. Arrived today, perfect except for an error my end. Doh! |
Ian S C | 17/02/2017 09:51:19 |
![]() 7468 forum posts 230 photos | Yes the Borosilicate tube will work, that's what Pyrex is. Here's the hot end of the little motor above, the hot cap is lying in front, behind that on the left is an AA size Alkaline cell casing(+ tit on wrong end), next is a Nicad battery case, the next two are an AA, and a AAA battery. I'v got a pile of old AA Nicads from old LED garden lights. |
