vintagengineer | 27/01/2017 19:50:00 |
![]() 469 forum posts 6 photos | Anybody know where I can get a set of drawings for a small bore spiral pipe bender? |
Mark C | 27/01/2017 19:54:27 |
707 forum posts 1 photos | Is that spiral as in "spiral pipe" or "spiral bend" like a coil spring? Mark |
vintagengineer | 27/01/2017 20:08:28 |
![]() 469 forum posts 6 photos | `Like a coil spring. On large sizes I use a powered pipe roller but I need to some in 1/4" copper. |
Chris Evans 6 | 27/01/2017 20:15:23 |
![]() 2156 forum posts | Iv'e made the curly petrol pipe for my pre war bike in 1/4" copper. I tried a small pipe bending kit and it was awkward to use so I just bent the tube round some 2" bar with my fingers, worked well. |
Mark C | 27/01/2017 20:18:28 |
707 forum posts 1 photos | Yes, I think if I had just one or two to coil I might turn a mandrel and make a guide for use on the lathe using very low back gear or by hand. This obviously prevents you from having a long tail at the start end... Mark |
Nick Hughes | 27/01/2017 20:22:28 |
![]() 307 forum posts 150 photos | Deleted Edited By Nick Hughes on 27/01/2017 20:29:53 |
John Reese | 27/01/2017 21:26:46 |
![]() 1071 forum posts | I would make a hardwood mandrel. I would thread the mandrel with a round form tool. After bending the coil unscrew the mandrel from the coil. Above a certain diameter the tube can be bent around a mandrel without the need for cutting thr profile into the mandrel. Unfortunately I don't know what that diameter is. |
Nick Hulme | 27/01/2017 21:31:27 |
750 forum posts 37 photos | Posted by vintagengineer on 27/01/2017 20:08:28:
`Like a coil spring. Do you mean a watch spring? That's a spiral. A compression coil spring is a helix |
Mark C | 27/01/2017 21:38:58 |
707 forum posts 1 photos | Oh OK, slap my wrist... Yes, you are correct, the question put the word at the front of my mind as I was thinking of spiral tubes - the sort made from a strip and clinched/welded into a tube as you often see in air conditioning and ducting systems Mark |
Brian Oldford | 27/01/2017 21:44:10 |
![]() 686 forum posts 18 photos | Can you not knock up a jig of some sort consisting essentially of two flanges spaced the tube diameter?
