Copper rivets
Chris Hammond17/01/2017 14:57:47
54 forum posts
Hi all
Can anyone help me with a UK supplier of 1/32 copper rivets, plus 3/64 copper and steel rivets please?
I've done a google search and found brass rivets at 1/32 but not copper.
Many thanks in advance.
Chris
Edited By Chris Hammond on 17/01/2017 14:58:27
norman valentine17/01/2017 15:07:02
280 forum posts
40 photos
GLR Kennions have the 3/64ths in copper and steel. For the 1/32nd rivets couldn't you just get some 1/32 copper wire and form your own heads?
Lambton17/01/2017 15:16:28
694 forum posts
Chris,
Try EKP Supplies Tel. 01598 710892
www.ekpsupplies.com
KWIL17/01/2017 15:21:00
3681 forum posts
70 photos
1/32" - 2" dia
JasonB17/01/2017 15:21:20
I have seen 1.0mm copper rivits from one of the german ME suppliers which is between 3/64 and 1/32
Chris Hammond17/01/2017 15:21:52
54 forum posts
Thanks guys. They aren't for me, but for a buddy in the States.
Emgee17/01/2017 16:16:50
2610 forum posts
312 photos
Posted by KWIL on 17/01/2017 15:21:00:
1/32" - 2" dia
Good link from KWIL
I'm amazed by the number and types of rivets supplied by this Birmingham based company, if they don't list a suitable rivet for your job I would be surprised.
Emgee
MW17/01/2017 16:25:37
2052 forum posts
56 photos
It's important to note the difference between copper rivets, which is simply a solid piece of copper that has to be hammered into position.
Whereas the self collapsing copper/aluminium rivets have a parent material main body and a steel mandrel, they wouldn't be able to function unless it had the strength of the steel to "draw upon" (pun intended).
Michael W
Edited By Michael-w on 17/01/2017 16:26:22
Chris Hammond17/01/2017 18:39:46
54 forum posts
Thanks all for taking the time to reply. Much appreciated.
D.A.Godley17/01/2017 22:44:23
143 forum posts
41 photos
Chris
I would recommend Sapphire Products , from whom I bought some just a few days ago , ordered Thursday , delivered Friday , their service is superb . I have no connection other than satisfied customer .
Chris Hammond17/01/2017 22:51:50
54 forum posts
Thanks D.A.G. - I'll check them out.
Jeff Chilver17/01/2017 23:59:29
27 forum posts
19 photos
Useful tip for "decorative " rivets i.e. tender sides running boards and similar locations where the rivet is not required to actually hold something .
Take a length of copper wire from scrap electrical twin and earth cable ( easy to scrounge offcuts ) I mostly use the earth conductor as you don't have to strip the insulation , anneal said bit of wire , drill a hole a neat fit for said wire . Cut a clean end on the wire using electrical snips without leaving an upstanding " V " on the end . It is most important that the end is flat . Lay job on a steel block and push the wire into the hole until it contacts the block . Drop a washer down the wire until it lays on the job ( you will need to experiment on a bit of scrap to get correct thickness of the washer Start with about 40 thou for a dummy 1/16 th size .) Using the snips with their flat face against the washer cut the wire flush with the washer . remove the washer and use a rivet snap to form a head on the protruding bit of copper . Takes one tap with a hammer . This dummy rivet wont fall out and neither will it leak if it is in an unpressurised tank . DO NOT do this if there is pressure involved also not suitable for holding components together .
Took a lot longer to write than it does to do it . P.S save the Washer( s) and bits of left over wire for future use .
Jeff.
Chris Hammond18/01/2017 11:01:27
54 forum posts
Thanks Jeff, great post. Will pass the advice on to my buddy.
Jeff Chilver18/01/2017 23:19:09
27 forum posts
19 photos
Chris pleased to be of help ,
Jeff
