Jeff Dayman | 08/01/2017 16:52:33 |
2356 forum posts 47 photos | Just a reminder for safety in the workshop in the New Year. Don't forget to check that your fire extinguisher is in the green on its' gauge. If you don't have one, get one. A phone you can call out on in a medical emergency is a good idea in the workshop. You can turn off the ringer so you are not interrupted, but still dial out if need be. A small first aid kit with disinfectant, band-aids, a large dressing pad, and long bandage gauze and tape, at a minimum is a handy thing. Safety eyewear is a must for many ops in the workshop. You can get them with bifocal magnifiers now too! A smoke alarm in the workshop, connected to the house smoke alarm system, is a good thing to have. A leak test with a brush and soapy water on all propane tank fittings and hose connections is a good idea yearly. Clean dust off electric heater housings and elements to reduce fire hazard. Good luck, JD
Emgee | 08/01/2017 17:03:08 |
2610 forum posts 312 photos | Good advice Geoff but don't forget to test the RCCB for correct functioning if the Test button is operated, or alternatively call in an electrician to test the device with a dedicated meter for time and current test function. Emgee |
Lambton | 08/01/2017 17:05:42 |
![]() 694 forum posts 2 photos | Never put your fingers where you would not put your 11th appendage! |
Tractor man | 08/01/2017 17:18:34 |
426 forum posts 1 photos | Good tip lambton. I wouldn't want to get my nose trapped in a machine. Lol |
V8Eng | 08/01/2017 17:32:19 |
1826 forum posts 1 photos | I am very surprised that no mention is made of protection for the feet, we are often moving heavy objects that would do a lot of damage if dropped on them! Safety footwear is relatively cheap and well worth the investment. |
JA | 08/01/2017 17:46:22 |
![]() 1605 forum posts 83 photos | And I cut my finger on a broken tap this afternoon. Pure stupidity. Had to go to the kitchen to wash it and put a sticky plaster on it. Still bleeding. JA |
MalcB | 08/01/2017 18:06:22 |
257 forum posts 35 photos | This subject begs the question: Which type of extinguisher do you actually have in there? |
Tractor man | 08/01/2017 18:17:33 |
426 forum posts 1 photos | Two malc a dry powder one and a carbon dioxide one. Probably the best for electrial fires etc. |
john swift 1 | 08/01/2017 18:27:49 |
![]() 318 forum posts 183 photos |
A Halon 1211 I could do with false paperwork to get it re charged since the inmates have taken over the asylum and stopped you and I from buying Halon extinguishers
