Connecting a DVD player to a monitor.
Mark P.13/12/2016 10:52:39
634 forum posts
9 photos
Hello all, here's a question for the electronics buffs. Can I connect a DVD player to a stand alone flat screen monitor so I can watch DVDs instead of using my laptops little screen? I don't have or want to buy a television.
Regards Mark P.
pgk pgk13/12/2016 11:04:14
2661 forum posts
294 photos
I'm no electronics buff.. but i guess it depends on the outputs of the dvd player and the inputs of the monitor you have or intend to get.
Personally I bought a 46" flat TV some years ago and matched it's RGB input to my PC's RGB output (probably be HDMI now) so I can watch DVD's with the PC's player, watch internet streamed stuff and back in the day actually see the numbers on a many columned spreadsheet.
Terrestrial reception here is pants so we don't bother or have a licence and the legacy sat dish here isn't connected.
There's also a  good chance your laptop has appropriate outputs for a monitor
Edited By pgk pgk on 13/12/2016 11:06:11
John Rudd13/12/2016 11:38:52
1479 forum posts
Posted by Mark P. on 13/12/2016 10:52:39:
Regards Mark P.
It all depends on the connectivity of the dvd player and the monitor. There's also the audio side to consider....does the monitor have inbuilt speakers?
If the dvd and the monitor have composite video and audio sockets then there's no reason why it shouldnt work...
If you dont already posses these items, then when buying, ask the seller the same question.....'Are these two items compatible to play a dvd? '
Gordon Tarling13/12/2016 12:31:59
185 forum posts
4 photos
All modern DVD players will have an HDMI output. There are also very many monitors which have HDMI input(s), so all you need is a single HDMI cable between them and you're sorted for video as well as audio if the speakers are built into the monitor.
SillyOldDuffer13/12/2016 13:37:57
10668 forum posts
2415 photos
Should be possible but depends on what the DVD and Monitor support. There are many possibilities. Are you able to post pictures of the various sockets they have round the back?
Bazyle13/12/2016 13:38:17
6956 forum posts
229 photos
Can you connect the laptop to the monitor, using the connector that is about 1/3 in high and 3/4 wide and has 3 rows of pins? If so you can divert the laptop screen onto the monitor with a special key combination which on mine is Fn + F3. Which connectors everything has is rather dependent on age.
Mark P.13/12/2016 13:56:52
634 forum posts
9 photos
Thanks for the replies. Not picked up the monitor or player yet, just checking that I can do what I want to do before I commit myself. Bazyl I really want to create a stand alone system without using the laptop.
Mark P.
Mike Poole13/12/2016 15:20:49
3676 forum posts
82 photos
Although you say you don't want to buy a TV it will solve you problem at a stroke, you do not need a licence to own a tv but you do if you receive live programmes on it. The connection will be just an HDMI cable and the will take care of everything. A monitor with sound will probably cost much the same as a TV. A new monitor will likely have a VGA port a DisplayPort or DVI or maybe HDMI. There are adaptors for HDMI to DVI but no sound. I think you need to choose a DVD player and shop for a monitor with suitable inputs to match your DVD player if the DVD player has audio outputs you can use a sound system for the audio. Also consider the size of a monitor, a widescreen will be more satisfactory for most DVD material. While I respect your position with the TV it will probably give you the most bangs for your buck and the simplest solution. My wife and I were TV free for about 5 years but persuading the license people we didn't use a TV was an annual event.
Also consider a blue ray player, these usually play DVD and audio discs and may future proof you if DVD is superseded by blue ray.
Edited By Michael Poole on 13/12/2016 15:25:53
Mark P.13/12/2016 15:26:13
634 forum posts
9 photos
Mike I may have to bite the bullet and buy a tv, not had one for 15 or so years!
Mark P.
HOWARDT13/12/2016 16:43:21
1081 forum posts
39 photos
I assume you are referring to a DVD player that is normally connected to a TV and not a DVD unit from a PC or Mac. If you use a DVD player and both have a HDMI connector then there shouldn't be a problem ( I think).
John Rudd13/12/2016 16:59:33
1479 forum posts
A suggestion that counters everything written thus far......
Buy a tv with an inbuilt dvd player.....job done, no wires no fuss....just insert and play!
Cant get any easier than that.....
Edited By John Rudd on 13/12/2016 17:04:57
Muzzer13/12/2016 17:08:46
2904 forum posts
448 photos
Have you ever seen one? Even if you have, it must leave a very narrow choice.
John Rudd13/12/2016 17:44:14
1479 forum posts
Yes I have seen them, I used to work in brown goods........
http://www.currys.co.uk/gbuk/tv-and-home-entertainment/televisions/televisions/logik-l24hed16-24-led-tv-with-built-in-dvd-player-10141132-pdt.html
https://finlux.co.uk/tv-22fce274b-nc
Why does everything always end up being a pi****** competition when it comes to offering advice and suggestions?
There's no need to jump down my throat.....
Edited By John Rudd on 13/12/2016 17:47:29
Neil Wyatt13/12/2016 19:01:06
19226 forum posts
749 photos
86 articles
If you want to avoid TV licence issues there are plenty of HDMI monitors for relatively cheap prices. Modern DVD players should all have HDMI out.
Just don't get ripped off for a gold-plated lead.
So teh answer to your question is yes.
Mark P.14/12/2016 12:08:55
634 forum posts
9 photos
Thank you all for your replies, turns out the monitor I have been given is for connecting a DVD player more inputs than you can shake a stick at!
Mark P.
Adrian Giles20/12/2016 03:04:40
70 forum posts
26 photos
Both of our bedroom tv's have built in disc players, very handy!
