sean logie | 08/12/2016 07:48:57 |
![]() 608 forum posts 7 photos | Can a forward reverse barrel switch be used on an induction single phase motor . The switch in question is the one in my albums. Sean |
john fletcher 1 | 08/12/2016 10:14:56 |
893 forum posts | Hello Sean, well it all depends on the contact arrangement within the barrel. with care it is possible to take a rotary switch to pieces and rearrange the contacts to form a forward/reverse with centre OFF. If you like a challenge. When I have done this in the passed, I did it inside a plastic bag, such when of those small spring fly off it didn't hit the workshop roof and get lost, but dropped to the bottom of the bag. Best if you form a truth table first, closed or open 0 1 for each pair of contacts, even then you might have to put in external links. Most the ones I've seen are for reversing a 3 phase motors and they haven't got sufficient terminals for single phase motor use. Even with a reversing switch your ought to have a proper motor starter with NO-Volt release and use it to stop and start the motor, not the forward and reversing switch.John |
sean logie | 08/12/2016 12:37:39 |
![]() 608 forum posts 7 photos | I used the switch on the old single phase motor that came with the lathe and it's still wired to the old motor . |
Les Jones 1 | 08/12/2016 12:57:07 |
2292 forum posts 159 photos | If it is working with one single pase motor then it will probably work with another one. You seem to expect solutions but are not prepared to give much information. You could have at least posted THE picture of the switch together with the manufacturer and model number. Les |
Bazyle | 08/12/2016 12:58:56 |
![]() 6956 forum posts 229 photos | Don't use it for the main on/off or the contacts will burn out, get adQAAOSw9r1WD9aK"> no volt release switch with emergency stop button. There have been other threads on here about wiring up the motor to a reversing switch. If it hasn't been fiddled with the drum switch is probably set up suitably but knowing which contacts to use is the difficult part. |
John Rudd | 08/12/2016 14:03:24 |
1479 forum posts 1 photos | Sean, The motor you intend to use the switch with, are there seperate terminals for the start winding and run windings? If the answer is yes, then the simplest way to having a bi-directional motor is to use a dpdt switch for the start winding.... If this is so, I'll sketch you a drawing in how to hook up said switch along with the nvr switch.... |
Robbo | 08/12/2016 14:21:41 |
1504 forum posts 142 photos | Sean, If the switch is the one (a Dewhurst) shown in your album "Getting to the bottom of thing.." then I wouldn't use it on our Christmas tree lights. Its contacts and posts are burned beyond redemption. In the interests of safety, get a new one. |
John Rudd | 08/12/2016 14:37:00 |
1479 forum posts 1 photos | I agree with Robbo, Re-using that switch is definitely not a good idea and would probably lead to injury......best place is the bin.. |
NJH | 08/12/2016 14:53:04 |
![]() 2314 forum posts 139 photos | Sean It is important to have an NVR ( Stop/Start ) switch which, in the event of a power cut, will disconnect the circuit and ensure that the machine will not restart when the power is restored ( and you are either far away or fiddling with your fingers in the works.) The reverse function I've yet to find a use for and you can safely put off purchase of that until you do have need of it. Norman Edited By NJH on 08/12/2016 14:55:24 |
sean logie | 08/12/2016 19:17:38 |
![]() 608 forum posts 7 photos | Posted by Les Jones 1 on 08/12/2016 12:57:07:
If it is working with one single pase motor then it will probably work with another one. You seem to expect solutions but are not prepared to give much information. You could have at least posted THE picture of the switch together with the manufacturer and model number. Les Calm down Les .... If you'd checked my albums you would've seen the switch in all it's glory .... I was on my phone at work when i posted this so i don't have the motor handy to take a photo of make and model ....Anyways for all the times I'll be needing reverse I'm not going to bother faffing about .... but if i change my mind I'll make sure of at LEAST posting some information of the motor and switch .... |
John Rudd | 08/12/2016 19:36:06 |
1479 forum posts 1 photos | In Les's defence, you stated that the switch was attached to the original motor, then asked if it would work with another motor without qualifying which motor you had in mind....hence my question on whether your 'new' motor has separate terms for Start and Run connections.... Getting upset doesnt really help....but information does..... Edited By John Rudd on 08/12/2016 19:36:32 |
sean logie | 08/12/2016 19:54:24 |
![]() 608 forum posts 7 photos | John .... I'm far from upset
Sean |
